Since some days I face similar problems.
Some basic information:
Raspberry Pi B, RaZberry Controller with following details: ProductID: 2/3, Chip ZW0301, SDK: 4.54.01, serial API version: 04.02, software version: v2.0.0.
Since October 2014 I have been using version z-way-server-RaspberryPiXTools-v1.7.2. without any problems. Based on that I implemented a lot in context of FHEM. Fibaro roller shutter have been working fine. Because of facing troubles with "Danfoss Thermostat living connect" I "switched" back to z-way-controller.
I installed version v2.0.0 and since that I does not have any more a stable situation.
Always stable is the access to the home page (
http://IP:8083); the GUI for Home Automation, TV and Mobile can be accessed. Choosing the Expert GU brings up in 95 % of all trials the message: "Error handling data from server".
The Logfile shows in case of errors (selection):
[2015-03-24 16:48:26.341] [D] [zway] Worker thread successfully finished
[2015-03-24 16:48:26.369] [I] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed
[2015-03-24 16:48:32.635] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
or
[2015-03-24 16:15:56.848] [I] [core] Starting storage...
[2015-03-24 16:15:56.852] [I] [core] ZWay Automation started
[2015-03-24 16:15:56.874] [I] [core] Terminating Z-Wave binding
[2015-03-24 16:16:01.894] [I] [core] Restarting Z-Wave binding
[2015-03-24 16:16:01.912] [I] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Binding with name 'zway' already exists
[2015-03-24 16:16:08.090] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
This are basically the two reasons for the malfunction.
In the rare cases of getting to the Expert UI the connection to the controller is available. The logfile looks as follows:
[2015-03-24 14:51:48.061] [D] [zway] Opened device: /dev/ttyAMA0
[2015-03-24 14:51:48.078] [D] [zway] Worker thread successfully created
[2015-03-24 14:51:48.081] [D] [zway] Worker thread entry point
[2015-03-24 14:51:48.119] [I] [zway] Adding job: Get controller info and supported function classes
[2015-03-24 14:51:48.119] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-03-24 14:51:48.121] [D] [zway] RECEIVED ACK
[2015-03-24 14:51:48.121] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x00
[2015-03-24 14:51:48.124] [D] [zway] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2015-03-24 14:51:48.125] [D] [zway] SENT ACK
[2015-03-24 14:51:48.125] [D] [zway] SETDATA controller.data.APIVersion = "04.02"
[2015-03-24 14:51:48.125] [D] [zway] SETDATA controller.data.manufacturerId = 327 (0x00000147)
[2015-03-24 14:51:48.126] [D] [zway] SETDATA controller.data.manufacturerProductType = 2 (0x00000002)
[2015-03-24 14:51:48.126] [D] [zway] SETDATA controller.data.manufacturerProductId = 3 (0x00000003)
[2015-03-24 14:51:48.133] [D] [zway] SETDATA controller.data.vendor = "RaZberry by Z-Wave.Me"
[2015-03-24 14:51:48.133] [D] [zway] Supported Function Classes:
[2015-03-24 14:51:48.133] [D] [zway] ---------------------------
[2015-03-24 14:51:48.134] [D] [zway] 0x02 SerialAPIGetInitData
[2015-03-24 14:51:48.134] [D] [zway] 0x03 SerialAPIApplicationNodeInformation
In all other cases the logfile is like:
[2015-03-24 16:48:25.698] [D] [zway] [54] "ZMECapabilities"
[2015-03-24 16:48:25.699] [D] [zway] Opened device: /dev/ttyAMA0
[2015-03-24 16:48:25.699] [D] [zway] Worker thread successfully created
[2015-03-24 16:48:25.701] [D] [zway] Worker thread entry point
[2015-03-24 16:48:25.711] [I] [zway] Adding job: Get controller info and supported function classes
[2015-03-24 16:48:25.712] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-03-24 16:48:25.917] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-03-24 16:48:25.917] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-03-24 16:48:26.123] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-03-24 16:48:26.123] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-03-24 16:48:26.329] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-03-24 16:48:26.329] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2015-03-24 16:48:26.329] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2015-03-24 16:48:26.329] [C] [zway] Get Serial API Capabilities returned zero.
[2015-03-24 16:48:26.329] [I] [zway] Removing job: Get controller info and supported function classes
[2015-03-24 16:48:26.340] [D] [zway] Worker thread exit point
During all these trials I stopped the Pi and booted again, even with couple of minutes between !
My "idea box" is empty !
Any ideas and hints are welcome !
Thanks in advance.
