When I do: http://10.10.10.80:8083/ZAutomation/api ... command/on
I recive: {"data":null,"code":401,"message":"401 Unauthorized","error":"Not logged in"}
I can't find any information regarding this, or where to set user access...
Please help..
SOLVED READ LAST POST!
SOLVED 2.0.2. Unauthorized","error":"Not logged in"
Re: 2.0.2 RC1 problems. Unauthorized","error":"Not logged in
If I goto: http://10.10.10.80:8083/smarthome/
and create a user: me
with pass: me1234
And try this:
http://me:me1234@http://10.10.10.80:808 ... command/on
Still not working from other IP/client on same LAN
Authentication is messy and not working at is should anymore!!!
Or how should I login and verify my self now??? All this was working before...
with pass: me1234
And try this:
I have the module Z-Wave Network Access Active.
Enable Z-Wave API
Handler HTTP requests to /ZWaveAPI/* and /ZWave//*
Allow public access to Z-Wave API
Do not ask for authentication to access Z-Wave API
Create virtual devices in Home Automation engine
Without this Z-Wave devices will be visible only in Expert UI and via Z-Wave API
Enable Z-Wave API
If anyone have a solution I will be very happy, I put alot of time and coding my own controlls and now after upgrading I can't send remote commands any more
Is it safe to downgrade? I read about corrupted admin accounts...
Sorry but getting abit desperate now!!
I tried to downgrade to last working version 2.0.1-rc31 and now:
Log file:
[2015-07-21 19:15:10.983] [core] Executing script: /* Start Core/Base */ ...
[2015-07-21 19:15:10.995] [core] Executing script: /* Start Core/Collection */ ...
[2015-07-21 19:15:11.007] [core] System: Loading Config
[2015-07-21 19:15:11.011] [core] System: Loading Boot Scripts
[2015-07-21 19:15:11.020] [core] System: Boot folder is empty
[2015-07-21 19:15:11.023] [core] System: Registering Models
[2015-07-21 19:15:11.033] [core] Executing script: /* System: User Model */ ...
[2015-07-21 19:15:11.041] [core] Executing script: /* System: Users Collections */ ...
[2015-07-21 19:15:11.049] [core] {"dataSource":"memory","public":false}
[2015-07-21 19:15:11.053] [core] Executing script: /* System: User Model */ ...
[2015-07-21 19:15:11.055] [I] [core] Executing script: /* System: Users Collections */ ...
[2015-07-21 19:15:11.064] [I] [core] {"dataSource":"filesystem","file":"users","public":true}
[2015-07-21 19:15:11.064] [I] [core] System: Registering Handlers
[2015-07-21 19:15:11.068] [I] [core] Executing script: /* System: Loaded Cors Handler */ ...
[2015-07-21 19:15:11.070] [I] [core] Executing script: /* System: Loaded Cors Handler */ ...
[2015-07-21 19:15:11.072] [I] [core] Executing script: /* System: Loaded Rest Handler */ ...
[2015-07-21 19:15:11.074] [I] [core] Executing script: /* System: Loaded Cors Handler */ ...
[2015-07-21 19:15:11.076] [I] [core] Executing script: /* System: Loaded Cors Handler */ ...
[2015-07-21 19:15:11.083] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-07-21 19:15:11.089] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-07-21 19:15:11.107] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-07-21 19:15:11.111] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-07-21 19:15:11.115] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-07-21 19:15:11.120] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2015-07-21 19:15:11.135] [I] [core] Executing script: /*** Main Automation webserver module ***************************************** ...
[2015-07-21 19:15:11.138] [I] [core] Executing script: // Make this testable by pulling in underscore from the parent module ...
[2015-07-21 19:15:11.144] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2015-07-21 19:15:11.166] [E] [core] result: Error: TypeError: Cannot read property 'indexOf' of undefined
at new AutomationController (automation/classes/AutomationController.js:48:74)
at automation/main.js:283:22
Downgrade not working and my z-wave controlled house is dead!
Need help........
Log file:
Need help........
upgraded to : z-way-server-RaspberryPiXTools-v2.0.2-rc1-12-g8364373.tgz
But still this problem:
root@zwave-raspberrypi:~# curl -s -LN --globoff http://10.10.10.80:8083/ZAutomation/api ... ommand/off
I found a solution / workaround..
Turn switch device 29 off from bash:
curl -s -LN --globoff 'http://10.10.10.80:8083/ZWaveAPI/Run/de ... 37].Set(0)'
Turn switch device 29 on from bash:
curl -s -LN --globoff 'http://10.10.10.80:8083/ZWaveAPI/Run/de ... 37].Set(1)'
Turn dimmer device 29 on from bash:
curl -s -LN --globoff 'http://10.10.10.80:8083/ZWaveAPI/Run/de ... l.Set(255)'
and off:
curl -s -LN --globoff 'http://10.10.10.80:8083/ZWaveAPI/Run/de ... vel.Set(0)'
and off:
fableman wrote:upgraded to : z-way-server-RaspberryPiXTools-v2.0.2-rc1-12-g8364373.tgz
i had this problem, but i had to flush by browser cache and reenter my user/password, then it started working again. i really hope this helps.
Re: SOLVED 2.0.2. Unauthorized","error":"Not logged in"
Please note that HTTP Authentication will not work, you need to pass data to api/v1/login and get a cookie (or header) and use it in next requests.
So, you should try, if 401, login and save the session ID and then use it in next curl request
To login with curl use this command, it saves cookie to file "cookie.txt" :
Now you control devices with command:
Be sure to use cookies.
curl -i -H "Accept: application/json" -H "Content-Type: application/json" -X POST -d '{"form":true,"login":"admin","password":"admin","keepme":false,"default_ui":1}' http://192.168.0.62:8083/ZAutomation/api/v1/login -c cookie.txt
curl http://192.168.0.62:8083/ZAutomation/api/v1/devices/ZWayVDev_zway_6-0-37/command/on -b cookie.txt
