I also got this sensor. My plan was to associate it with ZME_05436 blind controller and use it to block operation when my door is open, but I did not succeed. I wonder if it is related to this issue?
I managed to include the sensor, and to associate it with other devices. I also updated the 121 parameter to 272 to be sure.
I can see the sensor status just fine on the webpage of the razberry, and it updates when I remove the magnet from the sensor. However, none of the other associated devices respond to changes in the sensor.
I checked
http://products.z-wavealliance.org/products/1179. The paramater change means that the sensor is supposed to send both a binary sensor update and basic set command to all associated devices.
In the job queue for the razberry I indeed see two reports whenever the sensor status changes. So this seems to be OK.
However, other devices do not seem to act on these reports. I tried both the ZME_05436, and a Fibaro FGS-221.
Their status remains unchanged when the sensor changes state.
I did not even configure the ZME_05436 to interpret the sensor as a blocking device, I just wanted it to see it turn on and off. I also tried having only one device associated with the sensor. And having the 121 parameter set to 256 or 16, so it only sends one report. So far nothing worked.
So, has anyone been able to successfully associate anything other than the controller with this sensor?
If so, how did you manage to do that?
