Recessed Door Sensor gen5 - Aeon Labs
Have you support for this dorr sensor Recessed Door Sensor gen5 - Aeon Labs
Re: Recessed Door Sensor gen5 - Aeon Labs
I believe so.
I do not have one so I cannot say for sure, but the product is listed AOE_ZW089
I'm new to z-wave but from what I've read all devices should be compatible if they adhere to the z-wave standards. Whether that's true or not..
- Screenshot 2015-12-28 10.01.35.png (134.48 KiB) Viewed 10319 times
Thanks but this one works whery good. version2 gen5 dosent workSparkacus wrote:I believe so.
silverhack
For anyone else having problems with ver2 of this device, I got mine working correctly after I set parameter 121 to value 272 (4-byte) as per the information here:
https://aeotec.freshdesk.com/support/so ... eshooting-
After setting the parameter (and waking device) I pulled the battery to reset it and now I am getting the correct events.
