I did find many e-shops with lists that are highly inaccurate about compatibility unfortunately. Both positive and negative verdicts were not correct.pofs wrote:That list seems to have no single device incompatible with Z-WayProbably it is not very accurate.
Problematic Z-Wave devices list
Re: Problematic Z-Wave devices list
Added Z-Wave.me Merten Connect 505/6xxx to the problematic devices list
From the post you refer to it looks like the device is not a problem with Z-Way, but is with other devices (means it can not contol other than Merten). But Z-Way can catch events from it and handles them
Added your note to the list in the first post
PoltoS wrote:From the post you refer to it looks like the device is not a problem with Z-Way, but is with other devices (means it can not contol other than Merten). But Z-Way can catch events from it and handles them
Z-Way works better in the way that it actually is able to display events for both paddles BUT Z-Way is not able to to direct associations to control other devices directly.
EDIT:
Was now able to do associations!
Interview stage still shows one final dot as incomplete which causes the Merten switch not being visible in the standard GUI of Z-Way.
All other z-wave based home automation platforms I have tested has issues in either way and all of them (including Z-Way) has the problem that if one wants to get updates/events of paddle press into for example Z-Way then I have to associate each group (A to D on the dual paddle version) to the controller as well. BUT when doing this the Merten switch LOOSES the dimming functionality and works only as an ON/OFF switch?!
If I remove the associations to the controller and use direct associations with devices to be controlled then dimming works fine. Sooo strange!
AND to make things even more messy:
If I use the Merten USB Z-Wave stick and use their programming software for inclusion and creating associations then status updates and everything else just works perfect!
Is Merten using some special custom classes not documented that is causing these issues with other software platforms and USB sticks than Mertens own?
See more in my thread about these Merten 5051xx/5052xx (newer models called 5071xx/5072xx) where the 1 means the one paddle version and 2 means the 2 paddle version.
viewtopic.php?f=3423&t=22684
