I'd like to see a command 'toggle' added so that one can toggle a binary switch. I know that using the ZAutomation interface, you can set /command/on and command/off but if you use /command/toggle, nothing happens. I've already modified my local copy of DummyDevice to add a toggle option (as well as the cool icons for switches) but I can't find code that handles commands to real switches.
Thanks...
