Multilevel Switch (Blind) Command "Stop" don't work [SOLVED]
dantoine
Post by dantoine »
Hi, i think, that since version 2.2.3 the "Stop" Command for Multilevel Switches doesn't work anymore.
I can turn down and up my blinds with
 "http://<ip>:8083/ZAutomation/api/v1/devices/<device-id>/command/exact?level=0"
and
 "http://<ip>:8083/ZAutomation/api/v1/devices/<device-id>/command/exact?level=99"
But if i want stop the Blind on other position the url
"http://<ip>:8083/ZAutomation/api/v1/devices/<device-id>/command/stop"
Can someone help please?
Raspi 4 - (bullseye) Zwave Version 3.2.3 Raz 7 Pro, Serial API Version: 07.13
Re: Multilevel Switch (Blind) Command "Stop" don't work
Anything in the log when you issue it?
dantoine
Post by dantoine »
Hi, this is the log-output.
I have first sent:
and after few seconds i have sent:
After the stop-command, the blind is going back to 99%.
[2016-08-17 16:09:17.348] [I] [core] ---  ZWayVDev_zway_27-0-38 performCommand processing: {"0":"exact","1":{"level":"0"}}
[2016-08-17 16:09:17.349] [I] [zway] Adding job: SwitchMultilevel Set
[2016-08-17 16:09:17.350] [I] [zway] Adding job: SwitchMultilevel Get
[2016-08-17 16:09:17.351] [D] [zway] SENDING (cb 0x4b): ( 01 0B 00 13 1B 04 26 01 00 FF 25 4B 4E )
[2016-08-17 16:09:17.353] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:17.357] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:17.357] [D] [zway] SENT ACK
[2016-08-17 16:09:17.358] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:17.484] [D] [zway] RECEIVED: ( 01 07 00 13 4B 00 00 0D AD )
[2016-08-17 16:09:17.484] [D] [zway] SENT ACK
[2016-08-17 16:09:17.484] [I] [zway] Job 0x13 (SwitchMultilevel Set): Delivered
[2016-08-17 16:09:17.484] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:17.484] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2016-08-17 16:09:17.485] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 126 (0x0000007e)
[2016-08-17 16:09:17.485] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:17.485] [D] [zway] SendData Response with callback 0x4b received: received by recipient
[2016-08-17 16:09:17.485] [D] [zway] SETDATA devices.27.data.lastSend = 74723193 (0x04742f79)
[2016-08-17 16:09:17.485] [D] [zway] Job 0x13 (SwitchMultilevel Set): success
[2016-08-17 16:09:17.485] [I] [zway] Removing job: SwitchMultilevel Set
[2016-08-17 16:09:17.556] [D] [zway] SENDING (cb 0x4c): ( 01 09 00 13 1B 02 26 02 25 4C B1 )
[2016-08-17 16:09:17.558] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:17.562] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:17.562] [D] [zway] SENT ACK
[2016-08-17 16:09:17.562] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:17.617] [D] [zway] RECEIVED: ( 01 07 00 13 4C 00 00 05 A2 )
[2016-08-17 16:09:17.617] [D] [zway] SENT ACK
[2016-08-17 16:09:17.617] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2016-08-17 16:09:17.617] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:17.618] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:09:17.618] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 55 (0x00000037)
[2016-08-17 16:09:17.618] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:17.618] [D] [zway] SendData Response with callback 0x4c received: received by recipient
[2016-08-17 16:09:17.618] [D] [zway] SETDATA devices.27.data.lastSend = 74723206 (0x04742f86)
[2016-08-17 16:09:17.618] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2016-08-17 16:09:17.618] [I] [zway] Removing job: SwitchMultilevel Get
[2016-08-17 16:09:17.667] [D] [zway] RECEIVED: ( 01 09 00 04 00 1B 03 26 03 63 AC )
[2016-08-17 16:09:17.667] [D] [zway] SENT ACK
[2016-08-17 16:09:17.667] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:17.667] [D] [zway] SETDATA devices.27.instances.0.commandClasses.38.data.level = 99 (0x00000063)
[2016-08-17 16:09:18.859] [D] [zway] RECEIVED: ( 01 0C 00 04 00 1B 06 31 05 04 22 04 AE 52 )
[2016-08-17 16:09:18.859] [D] [zway] SENT ACK
[2016-08-17 16:09:18.859] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:18.859] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2016-08-17 16:09:18.859] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2016-08-17 16:09:18.861] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.scaleString = "W"
[2016-08-17 16:09:18.861] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.val = 119.800003
[2016-08-17 16:09:18.862] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4 = Empty
[2016-08-17 16:09:18.875] [I] [core] Notification: device-info (device-power): {"dev":"Fibar Group Power (27.0.49.4)","l":"119.8 W"}
[2016-08-17 16:09:18.905] [I] [core] [BaseModule-14] Set lastLevel to 119.8 for ZWayVDev_zway_27-0-49-4 (was 0)
[2016-08-17 16:09:24.655] [I] [core] ---  ZWayVDev_zway_27-0-38 performCommand processing: {"0":"stop","1":{}}
[2016-08-17 16:09:24.656] [I] [zway] Adding job: SwitchMultilevel Stop Level Change
[2016-08-17 16:09:24.657] [I] [zway] Adding job: SwitchMultilevel Get
[2016-08-17 16:09:24.657] [I] [zway] Adding job: SwitchMultilevel Set
[2016-08-17 16:09:24.657] [D] [zway] Job 0x13 (SwitchMultilevel Get): removing duplicate
[2016-08-17 16:09:24.665] [D] [zway] SENDING (cb 0x4d): ( 01 09 00 13 1B 02 26 05 25 4D B7 )
[2016-08-17 16:09:24.667] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:24.672] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:24.672] [D] [zway] SENT ACK
[2016-08-17 16:09:24.672] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:24.863] [D] [zway] RECEIVED: ( 01 07 00 13 4D 00 00 13 B5 )
[2016-08-17 16:09:24.863] [D] [zway] SENT ACK
[2016-08-17 16:09:24.864] [I] [zway] Job 0x13 (SwitchMultilevel Stop Level Change): Delivered
[2016-08-17 16:09:24.864] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:24.865] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:09:24.865] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 192 (0x000000c0)
[2016-08-17 16:09:24.865] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:24.866] [D] [zway] SendData Response with callback 0x4d received: received by recipient
[2016-08-17 16:09:24.866] [D] [zway] SETDATA devices.27.data.lastSend = 74723912 (0x04743248)
[2016-08-17 16:09:24.866] [D] [zway] Job 0x13 (SwitchMultilevel Stop Level Change): success
[2016-08-17 16:09:24.866] [I] [zway] Removing job: SwitchMultilevel Stop Level Change
[2016-08-17 16:09:24.935] [D] [zway] SENDING (cb 0x4e): ( 01 0B 00 13 1B 04 26 01 63 FF 25 4E 28 )
[2016-08-17 16:09:24.937] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:24.941] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:24.942] [D] [zway] SENT ACK
[2016-08-17 16:09:24.942] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:24.996] [D] [zway] RECEIVED: ( 01 07 00 13 4E 00 00 05 A0 )
[2016-08-17 16:09:24.997] [D] [zway] SENT ACK
[2016-08-17 16:09:24.997] [I] [zway] Job 0x13 (SwitchMultilevel Set): Delivered
[2016-08-17 16:09:24.997] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:24.998] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2016-08-17 16:09:24.998] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 55 (0x00000037)
[2016-08-17 16:09:24.998] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:24.999] [D] [zway] SendData Response with callback 0x4e received: received by recipient
[2016-08-17 16:09:24.999] [D] [zway] SETDATA devices.27.data.lastSend = 74723925 (0x04743255)
[2016-08-17 16:09:24.999] [D] [zway] Job 0x13 (SwitchMultilevel Set): success
[2016-08-17 16:09:24.999] [I] [zway] Removing job: SwitchMultilevel Set
[2016-08-17 16:09:25.068] [D] [zway] SENDING (cb 0x4f): ( 01 09 00 13 1B 02 26 02 25 4F B2 )
[2016-08-17 16:09:25.070] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:25.074] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:25.074] [D] [zway] SENT ACK
[2016-08-17 16:09:25.075] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:25.129] [D] [zway] RECEIVED: ( 01 07 00 13 4F 00 00 05 A1 )
[2016-08-17 16:09:25.130] [D] [zway] SENT ACK
[2016-08-17 16:09:25.130] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2016-08-17 16:09:25.131] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:25.131] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:09:25.131] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 55 (0x00000037)
[2016-08-17 16:09:25.132] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:25.132] [D] [zway] SendData Response with callback 0x4f received: received by recipient
[2016-08-17 16:09:25.132] [D] [zway] SETDATA devices.27.data.lastSend = 74723938 (0x04743262)
[2016-08-17 16:09:25.132] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2016-08-17 16:09:25.133] [I] [zway] Removing job: SwitchMultilevel Get
[2016-08-17 16:09:25.171] [D] [zway] RECEIVED: ( 01 09 00 04 00 1B 03 26 03 49 86 )
[2016-08-17 16:09:25.171] [D] [zway] SENT ACK
[2016-08-17 16:09:25.172] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:25.172] [D] [zway] SETDATA devices.27.instances.0.commandClasses.38.data.level = 73 (0x00000049)
[2016-08-17 16:09:25.178] [I] [core] Notification: device-info (device-status): {"dev":"Rollo Schlafzimmer","l":"73%"}
[2016-08-17 16:09:25.206] [I] [core] [BaseModule-14] Set lastLevel to 73 for ZWayVDev_zway_27-0-38 (was 99)
[2016-08-17 16:09:27.231] [I] [zway] Adding job: SwitchMultilevel Get
[2016-08-17 16:09:27.232] [D] [zway] SENDING (cb 0x50): ( 01 09 00 13 1B 02 26 02 25 50 AD )
[2016-08-17 16:09:27.243] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:27.243] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:27.244] [D] [zway] SENT ACK
[2016-08-17 16:09:27.244] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:27.467] [D] [zway] RECEIVED: ( 01 09 00 04 00 1B 03 26 03 4A 85 )
[2016-08-17 16:09:27.468] [D] [zway] SENT ACK
[2016-08-17 16:09:27.468] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:27.468] [D] [zway] SETDATA devices.27.instances.0.commandClasses.38.data.level = 74 (0x0000004a)
[2016-08-17 16:09:27.476] [I] [core] Notification: device-info (device-status): {"dev":"Rollo Schlafzimmer","l":"74%"}
[2016-08-17 16:09:27.502] [I] [core] [BaseModule-14] Set lastLevel to 74 for ZWayVDev_zway_27-0-38 (was 73)
[2016-08-17 16:09:27.979] [D] [zway] RECEIVED: ( 01 07 00 13 50 00 00 4A F1 )
[2016-08-17 16:09:27.980] [D] [zway] SENT ACK
[2016-08-17 16:09:27.981] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2016-08-17 16:09:27.981] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:27.982] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:09:27.983] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 737 (0x000002e1)
[2016-08-17 16:09:27.983] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:27.984] [D] [zway] SendData Response with callback 0x50 received: received by recipient
[2016-08-17 16:09:27.984] [D] [zway] SETDATA devices.27.data.lastSend = 74724215 (0x04743377)
[2016-08-17 16:09:27.985] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2016-08-17 16:09:27.985] [I] [zway] Removing job: SwitchMultilevel Get
[2016-08-17 16:09:29.353] [D] [zway] RECEIVED: ( 01 0D 00 04 00 0B 07 56 01 30 03 00 CF 3B 6A )
[2016-08-17 16:09:29.353] [D] [zway] SENT ACK
[2016-08-17 16:09:29.353] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:29.353] [D] [zway] SETDATA devices.11.instances.0.commandClasses.48.data.1.level = False
[2016-08-17 16:09:29.353] [D] [zway] SETDATA devices.11.instances.0.commandClasses.48.data.1 = Empty
[2016-08-17 16:09:29.375] [I] [core] Notification: device-info (device-OnOff): {"dev":"Fibar Group General purpose (11.0.48.1)","l":"off"}
[2016-08-17 16:09:29.438] [I] [core] [BaseModule-14] Set lastLevel to off for ZWayVDev_zway_11-0-48-1 (was on)
[2016-08-17 16:09:29.559] [I] [zway] Adding job: SwitchMultilevel Get
[2016-08-17 16:09:29.559] [D] [zway] SENDING (cb 0x51): ( 01 09 00 13 1B 02 26 02 25 51 AC )
[2016-08-17 16:09:29.561] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:29.565] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:29.565] [D] [zway] SENT ACK
[2016-08-17 16:09:29.565] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:29.803] [D] [zway] RECEIVED: ( 01 07 00 13 51 00 00 18 A2 )
[2016-08-17 16:09:29.803] [D] [zway] SENT ACK
[2016-08-17 16:09:29.804] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2016-08-17 16:09:29.804] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:29.804] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:09:29.804] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 238 (0x000000ee)
[2016-08-17 16:09:29.804] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:29.805] [D] [zway] SendData Response with callback 0x51 received: received by recipient
[2016-08-17 16:09:29.805] [D] [zway] SETDATA devices.27.data.lastSend = 74724390 (0x04743426)
[2016-08-17 16:09:29.805] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2016-08-17 16:09:29.805] [I] [zway] Removing job: SwitchMultilevel Get
[2016-08-17 16:09:29.853] [D] [zway] RECEIVED: ( 01 09 00 04 00 1B 03 26 03 56 99 )
[2016-08-17 16:09:29.854] [D] [zway] SENT ACK
[2016-08-17 16:09:29.854] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:29.854] [D] [zway] SETDATA devices.27.instances.0.commandClasses.38.data.level = 86 (0x00000056)
[2016-08-17 16:09:29.863] [I] [core] Notification: device-info (device-status): {"dev":"Rollo Schlafzimmer","l":"86%"}
[2016-08-17 16:09:29.890] [I] [core] [BaseModule-14] Set lastLevel to 86 for ZWayVDev_zway_27-0-38 (was 74)
[2016-08-17 16:09:31.891] [I] [zway] Adding job: SwitchMultilevel Get
[2016-08-17 16:09:31.891] [D] [zway] SENDING (cb 0x52): ( 01 09 00 13 1B 02 26 02 25 52 AF )
[2016-08-17 16:09:31.893] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:31.897] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:31.898] [D] [zway] SENT ACK
[2016-08-17 16:09:31.907] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:32.179] [D] [zway] RECEIVED: ( 01 07 00 13 52 00 00 1C A5 )
[2016-08-17 16:09:32.179] [D] [zway] SENT ACK
[2016-08-17 16:09:32.180] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2016-08-17 16:09:32.180] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:32.180] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:09:32.180] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 273 (0x00000111)
[2016-08-17 16:09:32.180] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:32.180] [D] [zway] SendData Response with callback 0x52 received: received by recipient
[2016-08-17 16:09:32.180] [D] [zway] SETDATA devices.27.data.lastSend = 74724620 (0x0474350c)
[2016-08-17 16:09:32.180] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2016-08-17 16:09:32.180] [I] [zway] Removing job: SwitchMultilevel Get
[2016-08-17 16:09:33.262] [I] [core] [Astronomy] Calculate
[2016-08-17 16:09:33.290] [I] [core] Notification: device-info (device-status): {"dev":"Solar altitude","l":"38.1 °"}
[2016-08-17 16:09:33.388] [I] [core] Notification: device-info (device-status): {"dev":"Solar azimuth","l":"239.6 °"}
[2016-08-17 16:09:33.632] [D] [zway] RECEIVED: ( 01 0C 00 04 00 1B 06 31 05 04 22 00 00 F8 )
[2016-08-17 16:09:33.633] [D] [zway] SENT ACK
[2016-08-17 16:09:33.633] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:33.633] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2016-08-17 16:09:33.633] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2016-08-17 16:09:33.635] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.scaleString = "W"
[2016-08-17 16:09:33.636] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.val = 0.000000
[2016-08-17 16:09:33.636] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4 = Empty
[2016-08-17 16:09:34.568] [I] [core] [BaseModule-14] Set lastLevel to 38.12371221179525 for Astronomy_10_altitude (was 38.25403206838861)
[2016-08-17 16:09:34.615] [I] [core] [BaseModule-14] Set lastLevel to 239.62310716414422 for Astronomy_10_azimuth (was 239.3765554603101)
[2016-08-17 16:09:34.693] [I] [core] Notification: device-info (device-power): {"dev":"Fibar Group Power (27.0.49.4)","l":"0 W"}
[2016-08-17 16:09:34.726] [I] [core] [BaseModule-14] Set lastLevel to 0 for ZWayVDev_zway_27-0-49-4 (was 119.8)
[2016-08-17 16:09:35.911] [D] [zway] RECEIVED: ( 01 09 00 04 00 1B 03 26 03 63 AC )
[2016-08-17 16:09:35.912] [D] [zway] SENT ACK
[2016-08-17 16:09:35.912] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:35.912] [D] [zway] SETDATA devices.27.instances.0.commandClasses.38.data.level = 99 (0x00000063)
[2016-08-17 16:09:35.918] [I] [core] Notification: device-info (device-status): {"dev":"Rollo Schlafzimmer","l":"99%"}
[2016-08-17 16:09:35.944] [I] [core] [BaseModule-14] Set lastLevel to 99 for ZWayVDev_zway_27-0-38 (was 86)
[2016-08-17 16:09:36.069] [D] [zway] RECEIVED: ( 01 0C 00 04 00 1B 06 31 05 04 22 00 00 F8 )
[2016-08-17 16:09:36.069] [D] [zway] SENT ACK
[2016-08-17 16:09:36.069] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:36.069] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2016-08-17 16:09:36.070] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2016-08-17 16:09:36.071] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.scaleString = "W"
[2016-08-17 16:09:36.072] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4.val = 0.000000
[2016-08-17 16:09:36.072] [D] [zway] SETDATA devices.27.instances.0.commandClasses.49.data.4 = Empty
[2016-08-17 16:09:37.965] [I] [zway] Adding job: SwitchMultilevel Get
[2016-08-17 16:09:37.966] [D] [zway] SENDING (cb 0x53): ( 01 09 00 13 1B 02 26 02 25 53 AE )
[2016-08-17 16:09:37.967] [D] [zway] RECEIVED ACK
[2016-08-17 16:09:37.972] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:09:37.972] [D] [zway] SENT ACK
[2016-08-17 16:09:37.973] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:09:38.038] [D] [zway] RECEIVED: ( 01 07 00 13 53 00 00 06 BE )
[2016-08-17 16:09:38.038] [D] [zway] SENT ACK
[2016-08-17 16:09:38.039] [I] [zway] Job 0x13 (SwitchMultilevel Get): Delivered
[2016-08-17 16:09:38.039] [D] [zway] SETDATA devices.27.data.lastPacketInfo.delivered = True
[2016-08-17 16:09:38.040] [D] [zway] SETDATA devices.27.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:09:38.040] [D] [zway] SETDATA devices.27.data.lastPacketInfo.deliveryTime = 66 (0x00000042)
[2016-08-17 16:09:38.040] [D] [zway] SETDATA devices.27.data.lastPacketInfo = **********
[2016-08-17 16:09:38.041] [D] [zway] SendData Response with callback 0x53 received: received by recipient
[2016-08-17 16:09:38.041] [D] [zway] SETDATA devices.27.data.lastSend = 74725187 (0x04743743)
[2016-08-17 16:09:38.041] [D] [zway] Job 0x13 (SwitchMultilevel Get): success
[2016-08-17 16:09:38.041] [I] [zway] Removing job: SwitchMultilevel Get
[2016-08-17 16:09:38.080] [D] [zway] RECEIVED: ( 01 09 00 04 00 1B 03 26 03 63 AC )
[2016-08-17 16:09:38.081] [D] [zway] SENT ACK
[2016-08-17 16:09:38.081] [D] [zway] SETDATA devices.27.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:38.081] [D] [zway] SETDATA devices.27.instances.0.commandClasses.38.data.level = 99 (0x00000063)
[2016-08-17 16:09:38.216] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:38.330] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:41.569] [D] [zway] RECEIVED: ( 01 09 00 04 00 0D 03 40 03 01 BE )
[2016-08-17 16:09:41.569] [D] [zway] SENT ACK
[2016-08-17 16:09:41.597] [D] [zway] SETDATA devices.13.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:41.598] [D] [zway] SETDATA devices.13.instances.0.commandClasses.64.data.mode = 1 (0x00000001)
[2016-08-17 16:09:42.205] [D] [zway] RECEIVED: ( 01 0D 00 04 00 0B 07 56 01 30 03 FF D1 CB 7B )
[2016-08-17 16:09:42.205] [D] [zway] SENT ACK
[2016-08-17 16:09:42.206] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:42.206] [D] [zway] SETDATA devices.11.instances.0.commandClasses.48.data.1.level = True
[2016-08-17 16:09:42.206] [D] [zway] SETDATA devices.11.instances.0.commandClasses.48.data.1 = Empty
[2016-08-17 16:09:42.218] [I] [core] Notification: device-info (device-OnOff): {"dev":"Fibar Group General purpose (11.0.48.1)","l":"on"}
[2016-08-17 16:09:42.249] [I] [core] [BaseModule-14] Set lastLevel to on for ZWayVDev_zway_11-0-48-1 (was off)
[2016-08-17 16:09:43.457] [D] [zway] RECEIVED: ( 01 09 00 04 00 07 03 40 03 01 B4 )
[2016-08-17 16:09:43.457] [D] [zway] SENT ACK
[2016-08-17 16:09:43.457] [D] [zway] SETDATA devices.7.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:43.457] [D] [zway] SETDATA devices.7.instances.0.commandClasses.64.data.mode = 1 (0x00000001)
[2016-08-17 16:09:45.579] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:45.702] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:45.825] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:48.621] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:50.405] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:52.760] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:09:56.953] [D] [zway] RECEIVED: ( 01 09 00 04 00 1A 03 20 03 FF 37 )
[2016-08-17 16:09:56.955] [D] [zway] SENT ACK
[2016-08-17 16:09:56.956] [D] [zway] SETDATA devices.26.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:09:56.957] [D] [zway] SETDATA devices.26.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2016-08-17 16:09:58.570] [D] [zway] Job 0x13: deleted from queue
[2016-08-17 16:10:00.178] [I] [core] ---  HTTP_Device_sensorBinary_19 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.185] [I] [core] ---  MiniKeypadTamper_35 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.186] [I] [core] ---  ZWayVDev_zway_16-0-50-0 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.187] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.188] [I] [core] ---  ZWayVDev_zway_17-0-49-4 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.188] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:00.188] [I] [core] ---  ZWayVDev_zway_17-0-50-0 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.189] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.190] [I] [core] ---  ZWayVDev_zway_17-0-50-2 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.190] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.191] [I] [core] ---  ZWayVDev_zway_18-0-50-2 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.191] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.191] [I] [core] ---  ZWayVDev_zway_19-0-49-4 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.192] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:00.192] [I] [core] ---  ZWayVDev_zway_19-0-50-0 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.193] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.193] [I] [core] ---  ZWayVDev_zway_19-0-50-2 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.193] [I] [core] ---  ZWayVDev_zway_20-0-50-0 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.194] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.194] [I] [core] ---  ZWayVDev_zway_21-0-49-4 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.194] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:00.195] [I] [core] ---  ZWayVDev_zway_21-0-50-2 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.195] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.195] [I] [core] ---  ZWayVDev_zway_24-0-49-4 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.196] [D] [zway] SENDING (cb 0x54): ( 01 0A 00 13 10 03 32 01 00 25 54 B7 )
[2016-08-17 16:10:00.196] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:00.196] [I] [core] ---  ZWayVDev_zway_24-0-50-0 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.197] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.197] [I] [core] ---  ZWayVDev_zway_24-0-50-2 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.198] [I] [core] ---  ZWayVDev_zway_25-0-49-4 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.198] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:00.198] [I] [core] ---  ZWayVDev_zway_25-0-50-2 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.198] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:00.199] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.199] [I] [core] ---  ZWayVDev_zway_27-0-50-0 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.199] [I] [core] ---  ZWayVDev_zway_27-0-50-2 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.200] [I] [zway] Adding job: Meter Get (v2)
[2016-08-17 16:10:00.200] [I] [core] ---  ZWayVDev_zway_29-0-49-4 performCommand processing: {"0":"update"}
[2016-08-17 16:10:00.200] [I] [zway] Adding job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:00.202] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:00.202] [D] [zway] SENT ACK
[2016-08-17 16:10:00.202] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:00.228] [D] [zway] RECEIVED: ( 01 07 00 13 54 00 00 02 BD )
[2016-08-17 16:10:00.228] [D] [zway] SENT ACK
[2016-08-17 16:10:00.228] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:00.228] [D] [zway] SETDATA devices.16.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:00.229] [D] [zway] SETDATA devices.16.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:00.229] [D] [zway] SETDATA devices.16.data.lastPacketInfo.deliveryTime = 25 (0x00000019)
[2016-08-17 16:10:00.229] [D] [zway] SETDATA devices.16.data.lastPacketInfo = **********
[2016-08-17 16:10:00.230] [D] [zway] SendData Response with callback 0x54 received: received by recipient
[2016-08-17 16:10:00.230] [D] [zway] SETDATA devices.16.data.lastSend = 74727340 (0x04743fac)
[2016-08-17 16:10:00.230] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:00.231] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:00.231] [D] [zway] SENDING (cb 0x55): ( 01 09 00 13 11 02 31 04 25 55 B3 )
[2016-08-17 16:10:00.237] [W] [zway] Received SOF, while awaiting ACK
[2016-08-17 16:10:00.237] [D] [zway] RECEIVED: ( 01 10 00 04 00 10 0A 32 02 21 44 00 00 00 03 00 00 A7 )
[2016-08-17 16:10:00.238] [D] [zway] SENT ACK
[2016-08-17 16:10:00.238] [D] [zway] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:10:00.239] [D] [zway] SETDATA devices.16.instances.0.commandClasses.50.data.0.val = 0.030000
[2016-08-17 16:10:00.240] [D] [zway] SETDATA devices.16.instances.0.commandClasses.50.data.0.delta = 0 (0x00000000)
[2016-08-17 16:10:00.240] [D] [zway] SETDATA devices.16.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2016-08-17 16:10:00.241] [D] [zway] SETDATA devices.16.instances.0.commandClasses.50.data.0 = Empty
[2016-08-17 16:10:00.247] [D] [zway] RECEIVED CAN
[2016-08-17 16:10:00.661] [I] [zway] Job 0x13 (SensorMultilevel V1-4 Get): No ACK received before timeout
[2016-08-17 16:10:00.662] [D] [zway] SENDING (cb 0x55): ( 01 09 00 13 11 02 31 04 25 55 B3 )
[2016-08-17 16:10:00.664] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:00.668] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:00.668] [D] [zway] SENT ACK
[2016-08-17 16:10:00.668] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:00.693] [D] [zway] RECEIVED: ( 01 07 00 13 55 00 00 02 BC )
[2016-08-17 16:10:00.693] [D] [zway] SENT ACK
[2016-08-17 16:10:00.693] [I] [zway] Job 0x13 (SensorMultilevel V1-4 Get): Delivered
[2016-08-17 16:10:00.694] [D] [zway] SETDATA devices.17.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:00.695] [D] [zway] SETDATA devices.17.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:10:00.695] [D] [zway] SETDATA devices.17.data.lastPacketInfo.deliveryTime = 25 (0x00000019)
[2016-08-17 16:10:00.696] [D] [zway] SETDATA devices.17.data.lastPacketInfo = **********
[2016-08-17 16:10:00.696] [D] [zway] SendData Response with callback 0x55 received: received by recipient
[2016-08-17 16:10:00.696] [D] [zway] SETDATA devices.17.data.lastSend = 74727385 (0x04743fd9)
[2016-08-17 16:10:00.697] [D] [zway] Job 0x13 (SensorMultilevel V1-4 Get): success
[2016-08-17 16:10:00.697] [I] [zway] Removing job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:00.698] [D] [zway] SENDING (cb 0x56): ( 01 0A 00 13 12 03 32 01 10 25 56 A7 )
[2016-08-17 16:10:00.703] [W] [zway] Received SOF, while awaiting ACK
[2016-08-17 16:10:00.703] [D] [zway] RECEIVED: ( 01 0C 00 04 00 11 06 31 05 04 22 00 00 F2 )
[2016-08-17 16:10:00.704] [D] [zway] SENT ACK
[2016-08-17 16:10:00.704] [D] [zway] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:10:00.705] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.4.deviceScale = 0 (0x00000000)
[2016-08-17 16:10:00.705] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.4.scale = 0 (0x00000000)
[2016-08-17 16:10:00.707] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.4.scaleString = "W"
[2016-08-17 16:10:00.708] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.4.val = 0.000000
[2016-08-17 16:10:00.708] [D] [zway] SETDATA devices.17.instances.0.commandClasses.49.data.4 = Empty
[2016-08-17 16:10:00.715] [D] [zway] RECEIVED CAN
[2016-08-17 16:10:01.114] [I] [zway] Job 0x13 (Meter Get (v2)): No ACK received before timeout
[2016-08-17 16:10:01.114] [D] [zway] SENDING (cb 0x57): ( 01 0A 00 13 11 03 32 01 00 25 57 B5 )
[2016-08-17 16:10:01.116] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.120] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.121] [D] [zway] SENT ACK
[2016-08-17 16:10:01.121] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.136] [D] [zway] RECEIVED: ( 01 07 00 13 57 00 00 02 BE )
[2016-08-17 16:10:01.137] [D] [zway] SENT ACK
[2016-08-17 16:10:01.137] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:01.137] [D] [zway] SETDATA devices.17.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.137] [D] [zway] SETDATA devices.17.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:01.137] [D] [zway] SETDATA devices.17.data.lastPacketInfo.deliveryTime = 16 (0x00000010)
[2016-08-17 16:10:01.138] [D] [zway] SETDATA devices.17.data.lastPacketInfo = **********
[2016-08-17 16:10:01.138] [D] [zway] SendData Response with callback 0x57 received: received by recipient
[2016-08-17 16:10:01.138] [D] [zway] SETDATA devices.17.data.lastSend = 74727428 (0x04744004)
[2016-08-17 16:10:01.138] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:01.138] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:01.139] [D] [zway] SENDING (cb 0x56): ( 01 0A 00 13 12 03 32 01 10 25 56 A7 )
[2016-08-17 16:10:01.146] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.146] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.147] [D] [zway] SENT ACK
[2016-08-17 16:10:01.147] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.197] [D] [zway] RECEIVED: ( 01 07 00 13 56 00 00 05 B8 )
[2016-08-17 16:10:01.197] [D] [zway] SENT ACK
[2016-08-17 16:10:01.197] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:01.198] [D] [zway] SETDATA devices.18.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.198] [D] [zway] SETDATA devices.18.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:01.198] [D] [zway] SETDATA devices.18.data.lastPacketInfo.deliveryTime = 50 (0x00000032)
[2016-08-17 16:10:01.198] [D] [zway] SETDATA devices.18.data.lastPacketInfo = **********
[2016-08-17 16:10:01.198] [D] [zway] SendData Response with callback 0x56 received: received by recipient
[2016-08-17 16:10:01.199] [D] [zway] SETDATA devices.18.data.lastSend = 74727434 (0x0474400a)
[2016-08-17 16:10:01.199] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:01.199] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:01.199] [D] [zway] SENDING (cb 0x58): ( 01 0A 00 13 11 03 32 01 10 25 58 AA )
[2016-08-17 16:10:01.207] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.207] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.207] [D] [zway] SENT ACK
[2016-08-17 16:10:01.207] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.228] [D] [zway] RECEIVED: ( 01 07 00 13 58 00 00 02 B1 )
[2016-08-17 16:10:01.228] [D] [zway] SENT ACK
[2016-08-17 16:10:01.228] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:01.228] [D] [zway] SETDATA devices.17.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.228] [D] [zway] SETDATA devices.17.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:01.229] [D] [zway] SETDATA devices.17.data.lastPacketInfo.deliveryTime = 20 (0x00000014)
[2016-08-17 16:10:01.229] [D] [zway] SETDATA devices.17.data.lastPacketInfo = **********
[2016-08-17 16:10:01.229] [D] [zway] SendData Response with callback 0x58 received: received by recipient
[2016-08-17 16:10:01.229] [D] [zway] SETDATA devices.17.data.lastSend = 74727437 (0x0474400d)
[2016-08-17 16:10:01.229] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:01.230] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:01.230] [D] [zway] SENDING (cb 0x59): ( 01 09 00 13 13 02 31 04 25 59 BD )
[2016-08-17 16:10:01.238] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.239] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.239] [D] [zway] SENT ACK
[2016-08-17 16:10:01.239] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.299] [D] [zway] RECEIVED: ( 01 07 00 13 59 00 00 06 B4 )
[2016-08-17 16:10:01.299] [D] [zway] SENT ACK
[2016-08-17 16:10:01.300] [I] [zway] Job 0x13 (SensorMultilevel V1-4 Get): Delivered
[2016-08-17 16:10:01.300] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.300] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:10:01.300] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 60 (0x0000003c)
[2016-08-17 16:10:01.300] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2016-08-17 16:10:01.301] [D] [zway] SendData Response with callback 0x59 received: received by recipient
[2016-08-17 16:10:01.301] [D] [zway] SETDATA devices.19.data.lastSend = 74727444 (0x04744014)
[2016-08-17 16:10:01.301] [D] [zway] Job 0x13 (SensorMultilevel V1-4 Get): success
[2016-08-17 16:10:01.301] [I] [zway] Removing job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:01.302] [D] [zway] SENDING (cb 0x5a): ( 01 0A 00 13 14 03 32 01 00 25 5A BD )
[2016-08-17 16:10:01.309] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.309] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.310] [D] [zway] SENT ACK
[2016-08-17 16:10:01.310] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.381] [D] [zway] RECEIVED: ( 01 07 00 13 5A 00 00 07 B6 )
[2016-08-17 16:10:01.381] [D] [zway] SENT ACK
[2016-08-17 16:10:01.381] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:01.381] [D] [zway] SETDATA devices.20.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.382] [D] [zway] SETDATA devices.20.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:01.382] [D] [zway] SETDATA devices.20.data.lastPacketInfo.deliveryTime = 71 (0x00000047)
[2016-08-17 16:10:01.382] [D] [zway] SETDATA devices.20.data.lastPacketInfo = **********
[2016-08-17 16:10:01.382] [D] [zway] SendData Response with callback 0x5a received: received by recipient
[2016-08-17 16:10:01.383] [D] [zway] SETDATA devices.20.data.lastSend = 74727452 (0x0474401c)
[2016-08-17 16:10:01.383] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:01.383] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:01.383] [D] [zway] SENDING (cb 0x5b): ( 01 0A 00 13 13 03 32 01 00 25 5B BB )
[2016-08-17 16:10:01.391] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.391] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.391] [D] [zway] SENT ACK
[2016-08-17 16:10:01.392] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.432] [D] [zway] RECEIVED: ( 01 10 00 04 00 14 0A 32 02 21 44 00 00 00 01 00 00 A1 )
[2016-08-17 16:10:01.432] [D] [zway] SENT ACK
[2016-08-17 16:10:01.432] [D] [zway] SETDATA devices.20.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:10:01.433] [D] [zway] SETDATA devices.20.instances.0.commandClasses.50.data.0.val = 0.010000
[2016-08-17 16:10:01.433] [D] [zway] SETDATA devices.20.instances.0.commandClasses.50.data.0.delta = 0 (0x00000000)
[2016-08-17 16:10:01.433] [D] [zway] SETDATA devices.20.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2016-08-17 16:10:01.433] [D] [zway] SETDATA devices.20.instances.0.commandClasses.50.data.0 = Empty
[2016-08-17 16:10:01.708] [D] [zway] RECEIVED: ( 01 07 00 13 5B 00 00 20 90 )
[2016-08-17 16:10:01.708] [D] [zway] SENT ACK
[2016-08-17 16:10:01.708] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:01.709] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.709] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:01.709] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 316 (0x0000013c)
[2016-08-17 16:10:01.709] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2016-08-17 16:10:01.710] [D] [zway] SendData Response with callback 0x5b received: received by recipient
[2016-08-17 16:10:01.710] [D] [zway] SETDATA devices.19.data.lastSend = 74727484 (0x0474403c)
[2016-08-17 16:10:01.710] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:01.710] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:01.711] [D] [zway] SENDING (cb 0x5c): ( 01 09 00 13 15 02 31 04 25 5C BE )
[2016-08-17 16:10:01.718] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.718] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.719] [D] [zway] SENT ACK
[2016-08-17 16:10:01.719] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.840] [D] [zway] RECEIVED: ( 01 07 00 13 5C 00 00 0D BA )
[2016-08-17 16:10:01.840] [D] [zway] SENT ACK
[2016-08-17 16:10:01.840] [I] [zway] Job 0x13 (SensorMultilevel V1-4 Get): Delivered
[2016-08-17 16:10:01.841] [D] [zway] SETDATA devices.21.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.841] [D] [zway] SETDATA devices.21.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-08-17 16:10:01.841] [D] [zway] SETDATA devices.21.data.lastPacketInfo.deliveryTime = 121 (0x00000079)
[2016-08-17 16:10:01.841] [D] [zway] SETDATA devices.21.data.lastPacketInfo = **********
[2016-08-17 16:10:01.842] [D] [zway] SendData Response with callback 0x5c received: received by recipient
[2016-08-17 16:10:01.842] [D] [zway] SETDATA devices.21.data.lastSend = 74727497 (0x04744049)
[2016-08-17 16:10:01.842] [D] [zway] Job 0x13 (SensorMultilevel V1-4 Get): success
[2016-08-17 16:10:01.842] [I] [zway] Removing job: SensorMultilevel V1-4 Get
[2016-08-17 16:10:01.843] [D] [zway] SENDING (cb 0x5d): ( 01 0A 00 13 13 03 32 01 10 25 5D AD )
[2016-08-17 16:10:01.850] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.850] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.851] [D] [zway] SENT ACK
[2016-08-17 16:10:01.851] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:01.911] [D] [zway] RECEIVED: ( 01 07 00 13 5D 00 00 07 B1 )
[2016-08-17 16:10:01.911] [D] [zway] SENT ACK
[2016-08-17 16:10:01.912] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:01.912] [D] [zway] SETDATA devices.19.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:01.912] [D] [zway] SETDATA devices.19.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:01.912] [D] [zway] SETDATA devices.19.data.lastPacketInfo.deliveryTime = 60 (0x0000003c)
[2016-08-17 16:10:01.912] [D] [zway] SETDATA devices.19.data.lastPacketInfo = **********
[2016-08-17 16:10:01.913] [D] [zway] SendData Response with callback 0x5d received: received by recipient
[2016-08-17 16:10:01.913] [D] [zway] SETDATA devices.19.data.lastSend = 74727504 (0x04744050)
[2016-08-17 16:10:01.913] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:01.913] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:01.914] [D] [zway] SENDING (cb 0x5e): ( 01 0A 00 13 15 03 32 01 10 25 5E A8 )
[2016-08-17 16:10:01.921] [D] [zway] RECEIVED ACK
[2016-08-17 16:10:01.921] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-17 16:10:01.922] [D] [zway] SENT ACK
[2016-08-17 16:10:01.922] [D] [zway] Delivered to Z-Wave stack
[2016-08-17 16:10:02.080] [D] [zway] RECEIVED: ( 01 0E 00 04 00 13 08 32 02 21 32 00 00 00 00 CD )
[2016-08-17 16:10:02.107] [D] [zway] SENT ACK
[2016-08-17 16:10:02.107] [D] [zway] SETDATA devices.19.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:10:02.107] [D] [zway] SETDATA devices.19.instances.0.commandClasses.50.data.2.val = 0.000000
[2016-08-17 16:10:02.108] [D] [zway] SETDATA devices.19.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2016-08-17 16:10:02.108] [D] [zway] SETDATA devices.19.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2016-08-17 16:10:02.109] [D] [zway] SETDATA devices.19.instances.0.commandClasses.50.data.2 = Empty
[2016-08-17 16:10:02.322] [D] [zway] RECEIVED: ( 01 07 00 13 5E 00 00 28 9D )
[2016-08-17 16:10:02.322] [D] [zway] SENT ACK
[2016-08-17 16:10:02.323] [I] [zway] Job 0x13 (Meter Get (v2)): Delivered
[2016-08-17 16:10:02.323] [D] [zway] SETDATA devices.21.data.lastPacketInfo.delivered = True
[2016-08-17 16:10:02.323] [D] [zway] SETDATA devices.21.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-08-17 16:10:02.323] [D] [zway] SETDATA devices.21.data.lastPacketInfo.deliveryTime = 401 (0x00000191)
[2016-08-17 16:10:02.324] [D] [zway] SETDATA devices.21.data.lastPacketInfo = **********
[2016-08-17 16:10:02.324] [D] [zway] SendData Response with callback 0x5e received: received by recipient
[2016-08-17 16:10:02.324] [D] [zway] SETDATA devices.21.data.lastSend = 74727542 (0x04744076)
[2016-08-17 16:10:02.324] [D] [zway] Job 0x13 (Meter Get (v2)): success
[2016-08-17 16:10:02.324] [I] [zway] Removing job: Meter Get (v2)
[2016-08-17 16:10:02.325] [D] [zway] SENDING (cb 0x5f): ( 01 09 00 13 18 02 31 04 25 5F B0 )
[2016-08-17 16:10:02.333] [W] [zway] Received SOF, while awaiting ACK
[2016-08-17 16:10:02.333] [D] [zway] RECEIVED: ( 01 0E 00 04 00 15 08 32 02 21 32 00 00 00 00 CB )
[2016-08-17 16:10:02.333] [D] [zway] SENT ACK
[2016-08-17 16:10:02.333] [D] [zway] SETDATA devices.21.data.lastReceived = 0 (0x00000000)
[2016-08-17 16:10:02.333] [D] [zway] SETDATA devices.21.instances.0.commandClasses.50.data.2.val = 0.000000
[2016-08-17 16:10:02.334] [D] [zway] SETDATA devices.21.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2016-08-17 16:10:02.334] [D] [zway] SETDATA devices.21.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2016-08-17 16:10:02.334] [D] [zway] SETDATA devices.21.instances.0.commandClasses.50.data.2 = Empty
Ineed, there is a bug.
Such change should fix it (add return in several places):
automation/modules/ZWave/index.js
@@ -1953,12 +1953,16 @@ ZWave.prototype.parseAddCommandClass = function (nodeId, instanceId, commandClas
                                        } else if ("stop" === command) { // Commands for Blinds
                                                cc.StopLevelChange();
+                                               return;
                                        } else if ("startUp" === command) {
                                                cc.StartLevelChange(0);
+                                               return;
                                        } else if ("startDown" === command) {
                                                cc.StartLevelChange(1);
+                                               return;
                                        } else if ("update" === command) {
                                                cc.Get(vDevId);
+                                               return;
                                        if (0 === newVal || !!newVal) {
dantoine
Post by dantoine »
Thank you very much!
Now it's working again. :D
