I'm new to z-wave. I have an old background in Unix and I'm interested in automation. So I decided to try to setup a Pi 3 with Z-Wave.
I tried with noobs, learned it, switched to jessie. Tried almost all the images available. With no success.
I'm able to setup the PI, connect in Ethernet or WiFi to my network. Able to setup the Z-Wave interface (or Jeedom)
I did all what was recommended to avoid the UART problem. But my Z-Wave network won't work.
I checked the board, the test is OK.
I measured the GPIO pins, voltage is OK.
I think I have an issue with the network. I edited my /etc/hosts. Changed the speed of the TTY, under clocked the PI, nothing works.
Which device tree is the right one to add at the end of /boot/config.txt ?
Is it pi3-disable-bt or pi3-miniuart-bt ?
What could prevent Z-Wave to communicate ?
I have a Raspberry Pi 3 Model B V1.2 2015 with a Z-Wave which looks like a Serie 500. But it looks like a mix between the image of the 300 and the 500 when I look at the images on http://razberry.z-wave.me
Thanks for your help !
