Thanks Minux, the module worked (unlike the other one, that did nothing). I have updated it a bit to deal with Ambience lights.
For Ambience lights my version now:
Creates a dimmer for colour temperature (unfortunately there's no proper UI element for this).
Doesn't create the unnecessary Saturation dimmer.
Optionally removes the on/off switch, and instead turns off when dimmed to 0.
I also fixed the polling for status updates, so on/off updates for non-RGBW lights and brightness update correctly.
Hopefully it does this without messing up the functioning of RGBW lights! But I don't have any to test, nor do I have any of the plan white ones to test (though I probably should tweak it so it auto detects them as well and just gives a slider or slider+switch).
Minux: Do you have a GitHub or something so people can contribute to the module?
bse4792: If you were hoping to use the Hue sensors and dimmers to control anything but Hue lights you're not going to have much luck. The Hue API doesn't have any ability to push events out, so it can't tell ZWay when a button is pushed or whatever. You can poll the status, but that would introduce unacceptable delay - it could be many seconds from the Hue sensor going off or a button being pressed to ZWay responding. Developers have apparently been going on at Phillips to add this feature for years, but nothing so far. In the meantime, while the lights are great I wouldn't advise buying their sensors or switches if you want to properly integrate them into a heterogeneous system (though I appreciate it might be too late for you!).
Philips Hue app?
Re: Philips Hue app?
I also couldn't get the "regular" hue app from the appstore to work. No control appear. I tried the beta version and it all worked. Thanks!
Current version doesn't seem to work for me neither.
z-way-log shows the following errors...:
[2017-01-02 22:18:31.383] [I] [core] PhilispHue Connection Authenticate OK
[2017-01-02 22:18:31.384] [E] [core] Callback execution error: TypeError: undefined is not a function
at Function.http.request.success (automation/userModules/PhilipsHue/index.js:82:14)
[2017-01-02 22:18:31.393] [I] [core] finished auth
Sure, there is a bug. Please change this to self in line 82
this.createDevices(rsp); ----> self.createDevices(rsp);
Please confirm and we will submit the fix to the app store
Changed it, but still no luck.
This time different errors thrown:
[2017-01-06 23:04:34.710] [I] [core] Instantiating module 183 from class PhilipsHue
[2017-01-06 23:04:34.711] [I] [core] --- Starting module Philips Hue
[2017-01-06 23:04:35.005] [I] [core] PhilispHue Connection Authenticate OK
[2017-01-06 23:04:35.005] [I] [core] PhilipsHue Create Devices
[2017-01-06 23:04:35.008] [E] [core] Callback execution error: TypeError: Cannot read property 'lightId' of undefined
at PhilipsHue.createDevices (automation/userModules/PhilipsHue/index.js:101:28)
[2017-01-06 23:04:35.013] [I] [core] finished auth
hm.. looks you have no lights in Hue. Can you add
console.logJS(deviceLights);
if (!deviceLights) return;
And show the log after restart, please
Of course (I have around 15-20 Hue lights running... ) And I can also access the Huebridge via Hue-Api, curl on the console. So from that side it must be okay.
Meanwhile I installed node-inspector (around 10times with different versions) before I finally got it to work somehow on my raspberrypi3 with jessie.
However, not much to see (see screenshot) except the little red message.
Shouldnt I see something more than just this lonely error message?
(Of course I activated DEBUG mode in zway and Port 8183 is also listening locally on the raspberry.)
Ideas?
Ideas?
- ss.png (142.83 KiB) Viewed 8662 times
Press on the arrow under Source and select modules/Sonos/index.js. Then place a breakpoint
Not much to select... Something's strange here?
- ss 1.png (84.07 KiB) Viewed 8659 times
