New 2.1.1 test build is ready!
Re: New 2.1.1 test build is ready!
Unfortunatelly I can't install/update to 2.1.1 with board manager on my Mac. The download works but I always got a crc error. I downloaded manually and checked the sha256 and it seems that really it doesn't match...
Ok, thanks. The crc seems to be corrected now!
I updated to 1.8.5 but my working sketch cannot be compiled. I used the ZUNO_BME280 lib from the forum but an #include "ZUNO_BME280.h" isn't working anymore. It complains that there is no such file or directory. But I can confirm it is there... maybe a general problem with local includes?
Edit: Switched back to 1.6.5 and the Sketch is compiling...
Hello!
We have released a new test build. To install it, delete the 2.1.1 folder from staging and package, download it again, then burn bootloader.
What was added/fixed:
- Added 3-channel firmware for JP and KR frequencies - requires bootloader change from the Arduino IDE
- Fully refactored Print to make the code smaller and use less stack
- Optimized code for float and printing float numbers to use less stack
- Added fixPrint() method to print fixed digets of a float
- Added dumpPrint() to help debug by printing big amounts of data (i.e. arrays/structures/any memory areas)
- Print() now uses three different prototypes to print byte, word and dword value - saves stack in most cases
- ZUNO_OLED refactored to use less stack.
- Fixed problem with prototypes not visible
- Fixed bug with local arrays not initialized (like in code void func() { byte a[]={1,2,3}; })
- Added Binary.h to the default header for Arduino style binary numbers definition
- Fixed problem with / on Windows (introduced in previous beta)
- Few examples changed to adop the changes above
FLIRS problem solved: I probably included the Z-Uno while it was in rescue mode. It is OK when I include my Z-Uno while it runs the user sketch.
I noticed updates on github... I did a quick test and I can now build on my windows machine! Looks like there are a lot of memory improvements too, I'll have to retest printing float to OLED!
Meet me here: https://forum.fibaro.com/index.php?/pro ... rgebruers/ or here: memberlist.php?mode=viewprofile&u=564463
Is this the same build as the final version?
Yes (only examples changed)
Can I connect 20 temperature sensors DS18B20 ?
Even 32! We have tested this in our lab.
