Error when uploading sketch
dawiinci
Post by dawiinci »
I always get this message when I want to upload a sketch after I already have uploaded one. I have to unplug the Z-UNO in order to upload. I'm on the latest release. Is this a bug?
RAW Info:
FIRMWARE DATA
(<type 'exceptions.IndexError'>, '<string>', 461)
Error 0 Unknown exception "list index out of range"
petergebruers
Re: Error when uploading sketch
Post by petergebruers »
I have seen something similar, but I cannot remember what caused it. Long shot: do you use debugging via serial over usb? I have been using debugging over seria uartl instead of usb for the last few months, and I think that might have solved it.
Select the correct port.
dawiinci
Post by dawiinci »
The port should be correct because it works the first time and after reconnecting. However I will check next time to be sure.
I'm not using debugging functions, but thanks for the hint.
dawiinci
Post by dawiinci »
I confirm the port is correct. I uploaded the sketch once and after it close the port I uploaded it again >> Error.
Now it doesn't work until I unplug it once.
