Color Switch in Z-uno for RGB leds
froggy
Post by froggy »
I'm trying to control some RBG leds with Z-uno. I used the ZUNO_SWITCH_COLOR() macro to set-up the channel as in the Reference page. In the controller (Razberry) the color switch is registered properly and I can select a color there. But when I change the RGB color, the Z-Uno setter function is called only once with the flag for the red color (with a value that should be assigned to the blue component). I was expecting this setter function to be called 3 times, one for each of the colors. Should this be working differently?
Re: Color Switch in Z-uno for RGB leds
Make sure to define color components correctly.
You can have a look on our configurator:
https://z-uno.z-wave.me/shield/configur ... C&pin12=NC
froggy
Post by froggy »
I don't use PWM to control the LEDs. I have WS2811 Led strips. I use this code to get the RGB values from the controller:
ZUNO_SETUP_CHANNELS(ZUNO_SWITCH_COLOR(SWITCH_COLOR_FLAGS_RED|SWITCH_COLOR_FLAGS_GREEN|SWITCH_COLOR_FLAGS_BLUE, getColor, setColor));
void setColor (byte color,byte value){
switch (color){
case SWITCH_COLOR_FLAGS_RED: Serial.println("SetColor red");
red = value;
break;
case SWITCH_COLOR_FLAGS_GREEN: Serial.println("SetColor green");
green = value;
break;
case SWITCH_COLOR_FLAGS_BLUE: Serial.println("SetColor blue");
blue = value;
byte getColor (byte color){
switch (color){
case SWITCH_COLOR_FLAGS_RED: return red;
case SWITCH_COLOR_FLAGS_GREEN: return green;
case SWITCH_COLOR_FLAGS_BLUE: return blue;
As you can see I added some message to the serial monitor to see what happens. The issue is, that when I change the color on the controller, the setColor function is called only once with the red component. It's not called for the blue and green.
We will check this issue. Thank you
You mixed flags (bitmasks) and constants.
in setter/getter you need to use SWITCH_COLOR_COMPONENT_xxx instead: https://github.com/Z-Wave-Me/Z-Uno-Core ... ons.h#L481
