Can not remove associations in Expert UI
Re: Can not remove associations in Expert UI
Please give us remote access to check it
I'll fix access. Where do I send credentials?
Hi z-wave.me,
Just wanted to say that you don't have to mind about the bug report I sent in to you about two months ago (before opening this thread) and don't mind this thread either. I have simply concluded that z-wave.me customer support is not compatible with the needs of a functioning home. I cannot have a "smart home" that reacts to commands like a dinosaur with long delays due to associations that are no longer valid and other things and consequently not a support organization the possess the same speed of response.
As a consequence of above, I have thrown out the Razberry card and replaced it with a Aeotec Z-stick and installed openHAB as a replacement for z-wave.me. It's been a number of interesting and sometimes frustrating years with z-wave.me but unfortunately, I can no longer trust the function of my home to z-wave.me.
I sincerely hope you will be able to build a professional support function, processes for release of code that involves unit, integration and system testing that avoids regression problems, feature bugs and shaky release cycles but for the time being, I can not wait for that to happen.
Over and out
Over and out
Pitty to read this. We will do our best to improve the service.
So what about this problem ? I have exactly the same case as brusan in first post. After excluding and including again in secure mode WallMote it is not going through with "AssociationGroupInformation". Getting "Aeotec WallMote Quad - Interview is not complete" and from Fibaro Double Switch 2
"- Removed associated devices."
Im checking my options for a working smart home but with z-way Im only getting more and more frustrated
Please help me to solve this issue @PoltoS
Please write by mail with all details to ps@ and smr@ and we will try to help you.
