so i know im new with this whole z wave stuff, i have been having trouble figuring out how to do a 3 speed fan control with a switch in the field
so far im thinking of using 3 relays for high med and low and having that change the speed just after the switch which will be low voltage dc
my concern is that if i change it through google home or the fibaro app will it try and turn 2 outputs on at the same time?
is there a way to have it regonise a contanst switch as a momentary one?
any help will be great
thanks
3 speed fan control
Re: 3 speed fan control
How powerful is the fan?
The simplest way would be with a dimmer, capable to control inductive loads (motors).
The problem is most dimmers are not designed to control inductive loads, or they are capable to control only a fraction of the power compared to the usually marketed restive load. You have to carefully read the specification.
I used Fan Coil Thermostat - Heltun
