Hello All
This is my first post, so I would like to say hello to everyone.
I'm new to Z Wave and home automation. After a internet search z wave looks like a good fit for my home automation project which hopefully will be more reliable than the Wi-Fi connection.
As I already have some experience in Node Red and a central heating automation running on the Raspberry Pi zero and ESP32 using MQTT to exchange information it will be ideal if I could continue to use Node Red and only replace Wi-Fi connection with z wave.
Is it possible to use z-uno and the RaZberry shield for Raspberry Pi with Node Red?
Z-wave and Node Red
Re: Z-wave and Node Red
Yes, I also use node-red for all my automation.
Here,s the right node : https://flows.nodered.org/node/node-red-contrib-zway
Hello. Thank you for the information. I will give it a go.
