Please see the FireFox site trust context menu (click on the shield in the url bar) -> settings. It states that there is no trust to the site and cookies are deleted on page close. This explains why it is logged out every time.
When I execute nslookup command I recieve a proper answer. My router seems to act as any regular DNS-Server.
If I access Smart Home UI via IP instead of the name it makes no difference. Neither with Firefox nor with Chrome it does remeber me.
In Firefox I even manually gave permissions to set cookies and use permanent memory, it still doesn't work.
I already configured Firefox to allow cookies, it still doesn’t work. Chrome on our Android smartphones allows cookies by default and it doesn’t remember the user either. It keeps asking for credentials twice, within the web page and in a pop up window.
There is no other website in my home network like Z-Way which I could use for comparison. They either don’t require authentication at all or they require authentication every time for security reasons.
Is it after browser restart or after Z-Way restart? If after browser restart - it is a browser issue. If after Z-Way restart - looks like Z-Way problem. May be you can check with Postman - get the token and make requests using that token via API. If Z-Way does not accept it after Z-Way reboot, then they are not saved correctly on the filesystem. Are you on v3.0.6?
I’m still on 3.05 because the changelog said nothing about this issue. It happens after browser restart in Microsoft Edge and Mozilla Firefox on my PCs and Google Chrome on Android devices.
With http requests and the API I’m still inexperienced but I’ll try this out.
Firefox shows cookies when pressing shift F9. Except of “WEBIF_IFLANG”, whose expiry date is June 2021, cookie lifetime of z-way is only until end of session. It appears to me that lifetime of z-way cookies isn't right.
