Hey there,
there is an app called valueovertaker, which does exactly what you are are looking for.
rws
Easy Scripting App - Documentation/Example
Re: Easy Scripting App - Documentation/Example
If you have two such scripts for both of the dimmers, it is an indirect loop.
18 changes => 5 is set to the same value and 5 is now changed => 18 is set to the same value,....
That's perfect, thank you! I searched for "bind", "master", "slave", "entangle", "attach", and probably others. It looks like the author's first language is not English: I wouldn't use the phrase "overtaking" to mean this. Maybe "taking over" would apply. But it would be nice if some of those key words could end up in the description.ridewithstyle wrote: ↑31 May 2020 23:19Hey there,
rws
Well sure, that would be a loop. But I don't have that. Just the one script. It seems that it isn't possible to fetch the value of a dimmer in an event triggered by that dimmer.
I set up a master dimmer as dummy device and then used value overtaker to muliply the settings to all instances. That way I don't have to worry about which device is master and which is notXan wrote: ↑01 Jun 2020 17:10That's perfect, thank you! I searched for "bind", "master", "slave", "entangle", "attach", and probably others. It looks like the author's first language is not English: I wouldn't use the phrase "overtaking" to mean this. Maybe "taking over" would apply. But it would be nice if some of those key words could end up in the description.ridewithstyle wrote: ↑31 May 2020 23:19Hey there,
rws
Hi there,
I just ran into an issue with triggering a script.
### ZWayVDev_zway_89-0-49-1 as temperature input trigger works fine. If I use ### ZWayVDev_zway_105-0-49-1, the script doesn't get triggered. I put both triggers into the script and no matter what I do, I can't get the 105 Trigger to work.
Any ideas? Is there a problem with three digit node ids?
Thanks and best regards,
rws
rws
update: ok, it's not the three digits, It tried to hook onto another sensor (ID104) to check if the script gets triggered and it does, triggering the sensor ID102 does not. I am out of ideas
[edit]reboot seems to fix the issue at first, somehow something gets stuck in regular use. Could that be the "loop detection" malfunctioning?
[2020-10-13 14:24:42.715] [I] [core] --- ZWayVDev_zway_102-0-49-1 performCommand processing: {"0":"update","1":{}}
[2020-10-13 14:24:42.716] [I] [zway] Adding job: SensorMultilevel V5 Get
[2020-10-13 14:24:42.726] [D] [zway] SENDING (cb 0x43): ( 01 0B 00 13 66 04 31 04 01 00 05 43 F7 )
[2020-10-13 14:24:42.729] [D] [zway] RECEIVED ACK
[2020-10-13 14:24:42.732] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-13 14:24:42.733] [D] [zway] SENT ACK
[2020-10-13 14:24:42.733] [D] [zway] Delivered to Z-Wave stack
[2020-10-13 14:24:44.272] [D] [zway] RECEIVED: ( 01 18 00 13 43 00 00 9A 02 C4 7F 7F 7F 7F 01 01 03 53 1C 00 00 02 02 1C 66 DD )
[2020-10-13 14:24:44.273] [D] [zway] SENT ACK
[2020-10-13 14:24:44.273] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2020-10-13 14:24:44.273] [D] [zway] SendData Response with callback 0x43 received: received by recipient
[2020-10-13 14:24:44.273] [D] [zway] SETDATA devices.102.data.lastSendInternal = **********
[2020-10-13 14:24:44.273] [D] [zway] SETDATA devices.102.data.lastSend = 14264042 (0x00d9a6ea)
[2020-10-13 14:24:44.274] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2020-10-13 14:24:44.274] [I] [zway] Waiting for job reply: SensorMultilevel V5 Get
[2020-10-13 14:24:44.346] [D] [zway] RECEIVED: ( 01 11 00 04 00 66 06 31 05 01 42 08 27 C4 00 02 1C 53 5B )
[2020-10-13 14:24:44.346] [D] [zway] SENT ACK
[2020-10-13 14:24:44.346] [D] [zway] SETDATA devices.102.data.lastReceived = 0 (0x00000000)
[2020-10-13 14:24:44.346] [D] [zway] Received reply on job (SensorMultilevel V5 Get)
[2020-10-13 14:24:44.347] [D] [zway] SETDATA devices.102.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2020-10-13 14:24:44.349] [D] [zway] SETDATA devices.102.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2020-10-13 14:24:44.349] [D] [zway] SETDATA devices.102.instances.0.commandClasses.49.data.1.val = 20.870001
[2020-10-13 14:24:44.349] [D] [zway] SETDATA devices.102.instances.0.commandClasses.49.data.1 = Empty
[2020-10-13 14:24:46.455] [D] [zway] Job 0x13: deleted from queue
[2020-10-13 14:25:02.053] [D] [zway] Job 0x3b: deleted from queue
[2020-10-13 14:25:11.361] [I] [zway] Adding job: Get background noise level
[2020-10-13 14:25:11.370] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2020-10-13 14:25:11.371] [D] [zway] RECEIVED ACK
[2020-10-13 14:25:11.372] [D] [zway] RECEIVED: ( 01 05 01 3B AA AE C4 )
[2020-10-13 14:25:11.372] [D] [zway] SENT ACK
[2020-10-13 14:25:11.372] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 170 (0x000000aa)
[2020-10-13 14:25:11.372] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 174 (0x000000ae)
[2020-10-13 14:25:11.372] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 127 (0x0000007f)
[2020-10-13 14:25:11.372] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -82 dBm, Ch#2: -82 dBm, Ch#3: invalid
[2020-10-13 14:25:11.372] [D] [zway] Job 0x3b (Get background noise level): success
[2020-10-13 14:25:11.373] [I] [zway] Removing job: Get background noise level
[2020-10-13 14:25:17.472] [I] [core] --- ZWayVDev_zway_104-0-49-1 performCommand processing: {"0":"update","1":{}}
[2020-10-13 14:25:17.473] [I] [zway] Adding job: SensorMultilevel V5 Get
[2020-10-13 14:25:17.483] [D] [zway] SENDING (cb 0x44): ( 01 0B 00 13 68 04 31 04 01 00 05 44 FE )
[2020-10-13 14:25:17.485] [D] [zway] RECEIVED ACK
[2020-10-13 14:25:17.488] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-10-13 14:25:17.489] [D] [zway] SENT ACK
[2020-10-13 14:25:17.489] [D] [zway] Delivered to Z-Wave stack
[2020-10-13 14:25:18.918] [D] [zway] RECEIVED: ( 01 18 00 13 44 00 00 8E 01 CA 7F 7F 7F 7F 01 01 03 1C 00 00 00 02 02 1C 68 9E )
[2020-10-13 14:25:18.918] [D] [zway] SENT ACK
[2020-10-13 14:25:18.918] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2020-10-13 14:25:18.918] [D] [zway] SendData Response with callback 0x44 received: received by recipient
[2020-10-13 14:25:18.919] [D] [zway] SETDATA devices.104.data.lastSendInternal = **********
[2020-10-13 14:25:18.919] [D] [zway] SETDATA devices.104.data.lastSend = 14267371 (0x00d9b3eb)
[2020-10-13 14:25:18.919] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2020-10-13 14:25:18.919] [I] [zway] Waiting for job reply: SensorMultilevel V5 Get
[2020-10-13 14:25:18.995] [D] [zway] RECEIVED: ( 01 10 00 04 00 68 06 31 05 01 42 08 7F CA 00 01 1C 52 )
[2020-10-13 14:25:18.995] [D] [zway] SENT ACK
[2020-10-13 14:25:18.995] [D] [zway] SETDATA devices.104.data.lastReceived = 0 (0x00000000)
[2020-10-13 14:25:18.996] [D] [zway] Received reply on job (SensorMultilevel V5 Get)
[2020-10-13 14:25:18.996] [D] [zway] SETDATA devices.104.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2020-10-13 14:25:18.997] [D] [zway] SETDATA devices.104.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2020-10-13 14:25:18.997] [D] [zway] SETDATA devices.104.instances.0.commandClasses.49.data.1.val = 21.750000
[2020-10-13 14:25:18.997] [D] [zway] SETDATA devices.104.instances.0.commandClasses.49.data.1 = Empty
[2020-10-13 14:25:19.879] [I] [core] Schlafzimmer Thermostat Dad Mode starting <-- easy_scripting
[2020-10-13 14:25:19.881] [I] [core] Schlafzimmer Thermostat Dad Mode exiting
The old loop detection system had no final in try-except-final. So any error blocked work of EasyScripting. Fixed in v3.1.0 and upper
I understand event triggered script, but what if i want to call my easyscript from If-Then app like a scene. Is it only possible via a dummy scene and the script subscribing to it?
Why to to that? You cave Code Device and JS Code app for this. If you want it because you like EasyScripting syntax helpers, yes, a dummy scene will be the solution. We can impove EasyScripting to add a checkbox to create a Dummy Scene right from the EasyScripting. Is it something worth doing?
