I'm trying to update my razberry's firmware
I'm not using z-way
With the update tool, I ran the command ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyAMA0
It gave me VERSION: 05 25
But in the map of firmwares I don't see version 5.25
Thanks for your help
Update razberry firmware
Re: Update razberry firmware
Wondering if this was hex?
Finally, its Hex. I have version 5.37 and bootlader 48059
but when I try to update, I have an error:
pi@jeedom:~/ZMESerialUpdater/arm $ ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyAMA0 -f UPD_FIRMWARE_Razberry_STATIC_2ch_ZME_05_25_04000002_ZME_05_27_04000002.bin
Z-WAVE Serial API Tool
Version:LWE0.9
by Z-WAVE>ME
Device ready in:3.07782196999 seconds
FIRMWARE
Openning port .............................. OK
Writing NVM data .............................. FAILED
Error 0 returned 1 for ACK
Error 1 Unknown exception:Can't write NVM data! at=30200
Sure Z-Way (or other s/w using RaZberry) is stopped?
I''m also puzzled about the whole firmware upgrade thing..
The command line is showing me this for UZB:
pi@raspberrypi:~/ZMESerialUpdater/arm $ ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0 | grep -E "(FREQ|VERSION)"
VERSION: 05 21 VENDOR: 01 15
FREQ: EU
Am I good with the firmware level ? I looked at the map but cannot find version 05.21 on it
FREQ: EU
Ok, but can I move forward all the way ?
Just make a backup of your sd card and try....I think I always updated some month late, when a new version is out.
Backup of the SD card? we are talking about updating the firmware of the UZB device here, not about new software or Rpi firmware.
So I think backing up the sd card does not bring any value here.
Yes, you are right, my mistake. So just update and see what will happen. Your choice.
