Z-Uno and Z-Uno Shiled. Request for improvements
Re: Z-Uno and Z-Uno Shiled. Request for improvements
March. Development took longer than we expected ;(
aleconakad
A better HW serial controller, that can do 7,8,9 bits and able to handle parity and up to 2 stop bits, with support for higher bitrates (115.2K). At the moment I have to revert to Software Serial but it is so not performant on 8051 uC.
I require it mainly for RS485/Modbus communication.
aleconakad
The ability to send RAW Zwave commands for association groups. This intended for experts only. One use case would be to change the configuration of a node on the fly. For example I use some RGBW dimmers from Fibaro and I lack the ability to start an animation program without reverting back to the controller.
The serial on Z-Uno G2 will do all CP2102 can do.
As for raw commands we there is zunoSendDbg that can send any command
aleconakad
Is zunoSendDbg something that one can use already in 2.1.7, or will it be something solely for the G2?
This is present from 2.1.0 for debuggin purposes, but one can use it to send raw commands
