my old trusty Vera Lite died a few days ago in my remote location. I look for a new Z-wave controller now, testing different ones in a demo. Long story short, I can't seem to get the UZB to work in Zway. I tried the pre-build images, different sd cards, Raspi 4, Raspi 1B+, a fresh buster with zway install via the usual command, I tried connecting the UZB before power, after power,... I see the UZB at /dev/ttyACM0 ... But whatever I do in the settings of the Zway "Z-Wave Network Access" app, the UZB won't be recognized, I have set the port to "/dev/ttyACM0". In expert mode, controller details, shows mostly blank...
In openHab3 on the same Raspberry 4 (different system image) the UZB works and I can control my demo setup. Is Zway not happy that the UZB has a network key and devices associated already to it? Homeassistant also works normally.
Is there something I am missing with the Zway setup?
//removed attachments, not relevant
Can't get the UZB to work, will work in openHab3
kellyjelly34
kellyjelly34
Re: Can't get the UZB to work, will work in openHab3
can it be zway doesn't like the old-school UZB with FW 5.00? At least that's apparently the one I have, you guys probably can confirm from the screenshot attached?
- UZB Version 05 00 VENDOR 01 15
- Oldschool UZB FW 5.00.png (16.13 KiB) Viewed 4372 times
kellyjelly34
Tried upgrading FW and/or bootloader, no luck. It´s doing something but won´t go through in the end. I can "readnvm" but not much else. The -c argument from the "manual" seems to be invalid, so can´t reset the UZB either.
kellyjelly34
With the proper commands, I was able to flash the 5.02 firmware manually. The published manual on the website is complete crap. After the update of the FW to 5.02 (successful, see comand below), the UZB shows up in Zway expert mode with all it´s details. From there I updated further to 5.06 which seems to be the maximum for this HW revision. Changed frequency to EU also via "expert mode". Attached now my status for the UZB.
Note to the team: Update your f****** manuals!
./ZMESerialUpdater serialapi_firmware -d /dev/ttyACM0 firmware_UZB_from_05_00_to_05_02.bin- Attachments
- Success!
- UZB updated.png (34.28 KiB) Viewed 4368 times
Hey, you are upgrading a 7 years old device! The manual is made for pretty modern devices
You had to update 5 years ago when the manual was up to date for 5.00-5.07
We will check it and try to make a corresponding note in our online manual
