Razberry me 7 and or software 3.2.3
disneyjoe7
Post by disneyjoe7 »
Hello All,
Find website of equipment my system of Z-way doesn't show at times the switch update of states. I seen this when Daylight sensor tripped and works a IF/THEN statement if this turns off / turn on Outside lights 4 of them. Lights tripped on ok but website screen doesn't show new state of light, showing still off.
My setup
Raspberrypi 3b 32bit OS Debian
Razberryme 7
3.2.3 software for Z-wayme
lanbrown
Re: Razberry me 7 and or software 3.2.3
Post by lanbrown »
This is the same issue that you have already reported before and the answer is the same!
disneyjoe7
LOL thought it was a slight difference so I posted it.
Steve
lanbrown
Post by lanbrown »
Go and look at the log and see if you see the same message. Same message = same problem.
micky1500
Post by micky1500 »
Doesn't make sense.
If Z-way app changed the state, It would have updated it's State.
Don't use IF/THEN App ! Use A Rule to make the IF/THEN decision.
Maybe consider adding the NIFFLER App, For older devices that don't respond correctly.
