Help with Z-way software setup/install
Re: Help with Z-way software setup/install
Thanks for your feedback.
Would be nice to see the log to understand the issue. It might be a device problem.
The trick you used is a workaround and is not solving the real issue.
You are right, but in most cases it is working without any seen problems and it´s difficult for non Linux users to
find all the information you or your programmer need.
400HPMustang
I wanted to circle back on the HomeKit part of this, it might be worth adding to the official instructions for windows that if it's not already installed the user should install Bonjour. After googling some random things I came across that it might help and sure enough after installing Bounjor to handle mDNS I was able to use the HomeKit gate.
I still cannot get the Home Assistant integration to work.
