i bought my zuno like 4 years ago i reckon and never did anything with it.
Ive decided to break it out and would like to build on the 4 power relay example.
Basically i want to have 4 momentary switches as inputs to manually turn the relays on and off.
Id also like to add a temperature and humidity sensor...
End use is the heat lamps x2, fan and light in the bathroom with a humidity sensor to auto start the fan...
four power relay example
- Contact:
Re: four power relay example
All that is possible. How can the community help you?
- Contact:
Hi PoltoS,
I guess im struggling with mashing together the programming. I butchered the 4 relay example and then tried to add external switches into the mix, but i just couldnt get it to compile and i dont know what the errors mean.
This is my code (It wouldnt let my upload the ino file?)
// Global variables
byte buttonState1;
byte buttonState2;
byte buttonState3;
byte buttonState4;
byte switchValue1 = 0;
byte switchValue2 = 0;
byte switchValue3 = 0;
byte switchValue4 = 0;
// Z-Wave channels
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getterButton1),
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getterButton2),
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getterButton3),
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getterButton4),
ZUNO_SWITCH_BINARY(getterSwitch1, setterSwitch1),
ZUNO_SWITCH_BINARY(getterSwitch2, setterSwitch2),
ZUNO_SWITCH_BINARY(getterSwitch3, setterSwitch3),
ZUNO_SWITCH_BINARY(getterSwitch4, setterSwitch4)
void setup() {
pinMode(19, INPUT);
buttonState1 = !digitalRead(3);
pinMode(20, INPUT);
buttonState2 = !digitalRead(4);
pinMode(21, INPUT);
buttonState3 = !digitalRead(5);
pinMode(22, INPUT);
buttonState4 = !digitalRead(6);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
void loop() {
// put your main code here, to run repeatedly:
byte _buttonState1 = digitalRead(19);
if (buttonState1 != _buttonState1) {
buttonState1 = _buttonState1;
zunoSendReport(1);
byte _buttonState2 = digitalRead(20);
if (buttonState2 != _buttonState2) {
buttonState2 = _buttonState2;
zunoSendReport(2);
byte _buttonState3 = digitalRead(21);
if (buttonState3 != _buttonState3) {
buttonState3 = _buttonState3;
zunoSendReport(3);
byte _buttonState4 = digitalRead(22);
if (buttonState4 != _buttonState4) {
buttonState4 = _buttonState4;
zunoSendReport(4);
digitalWrite(9, switchValue1 ? HIGH : LOW);
digitalWrite(10, switchValue2 ? HIGH : LOW);
digitalWrite(11, switchValue3 ? HIGH : LOW);
digitalWrite(12, switchValue4 ? HIGH : LOW);
delay(20);
// Getters and setters
byte getterButton1() {
return buttonState1;
byte getterButton2() {
return buttonState2;
byte getterButton3() {
return buttonState3;
byte getterButton4() {
return buttonState4;
void setterSwitch1(byte value) {
switchValue1 = value;
byte getterSwitch1() {
return switchValue1;
void setterSwitch2(byte value) {
switchValue2 = value;
byte getterSwitch2() {
return switchValue2;
void setterSwitch3(byte value) {
switchValue3 = value;
byte getterSwitch3() {
return switchValue3;
void setterSwitch4(byte value) {
switchValue4 = value;
byte getterSwitch4() {
return switchValue4;
I have nil experience using this... which im sure will be plainly obvious...
C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6/4 way relay with switch input zuno.ino
--- USING a list of libraries from:
C:\Users\doini\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.8\libraries
c:\Users\doini\OneDrive\Documents\Arduino\libraries
*** Collecting prototypes...
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\Custom.c with SDCPP...
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\Print.cpp with SDCPP...
Compiling C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\Print_sdcpp_.cpp ...
Print_sdcpp_.cpp:543:17& has lower precedence than ==; == will be evaluated first
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\Stream.cpp with SDCPP...
Compiling C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\Stream_sdcpp_.cpp ...
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\HardwareSerial.cpp with SDCPP...
Compiling C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\HardwareSerial_sdcpp_.cpp ...
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\HLCore.cpp with SDCPP...
Compiling C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\HLCore_sdcpp_.cpp ...
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\EEPROM.cpp with SDCPP...
Compiling C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\EEPROM_sdcpp_.cpp ...
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\4 way relay with switch input zuno.cpp with SDCPP...
Compiling C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\4 way relay with switch input zuno_sdcpp_.cpp ...
Preprocessing file: C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\ZWSupport.cpp with SDCPP...
Compiling C:\Users\doini\AppData\Local\Temp\arduino-sketch-203E8FD2854AA30CD0673EE4D64A6EF6\ZWSupport_sdcpp_.cpp ...
ZWSupport_sdcpp_.cpp6:error:variable has incomplete type 'void'
ZWSupport_sdcpp_.cpp22:error:expected ';' after top level declarator
uCxx returned error code:1
exit status 1
Compilation error: exit status 1
Thanks for any and all help.
Josh
