Beneath Arduino is a folder "librarys" in that folder is for example a folder OneWire.
In folder OneWire is OneWire.h and OneWire.cpp and still I get this error when compiling.
Arduino/DS18x20_Temperature_GitHub/DS18x20_Temperature_GitHub.ino:4:10: fatal error: OneWire.h: No such file or directory
#include "OneWire.h"
compilation terminated.
My .ino-file starts like:
/ ******************************** DS18x20_Temperature_GitHub ******************
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// https://github.com/milesburton/Arduino- ... ol-Library
OneWire ds(11); // on pin 10 (a 4.7K resistor is necessary)
void setup(void) {
Serial.begin(9600);
and even if I use <> instead of "" I get the same error.
Why?
OneWire.h can't be found -> Error
Re: OneWire.h can't be found -> Error
I forgot to tell, I'm trying to compile for a Z-Uno 2g...
Please use our examples (from the File > Examples > Z-Uno G2 > ...). Our implementation of OneWire is a bit different, but has almost the same functionality and API
Ok.
Where can I find more information about zuno_onewire.h and cpp?
