Extra Zwave Classes
rbmace
Still no luck
Post by rbmace »
Hi Poltos,
Still no luck, it wont recognize the Tag reader is I want to include/exclude it from the Zway. I reinstalled the Zway software like you mentioned. It should recognize the reader I presume because of the basic classes and other supported classes?
Thanks for your help.
It will certainly recognize
It will certainly recognize it itself, since the version we have tested (which is in the DB) is certainly not same as the one you have. But you should be able to pick it up from the list if you choose it manually
rbmace
It worked
Post by rbmace »
It worked finally. What I needed to do was to first exclude the new device, while it even want in the zwave network. After the exclude command i did an include command and than the Zway saw the new Zwave Device.
