New version of RaZberry is released
Yes, Kwikset Z-Wave Door Lock
Yes, Kwikset Z-Wave Door Lock works with RaZberry!
There is still one issue with most Secure devices (and Kwikset too): the interview stops after Security passed. To solve this just open Interview results dialog and press Force on those that are still unfinished.
We are working on this issue.
digistump
Schlage locks
Post by digistump »
Are Schlage z-wave locks supported?
rabing
Device Images are gone
Post by rabing »
The device Image URL seems to be local to your desktop:
deviceImage url="http:///var/www/zwavedevlib/symfony/uploads/resources/..."
Since I don't have this directory on my workstation, I see only the broken image symbol
in the "Devices configuration" tab of the webinterface.
Thanks, we have seen this too
Thanks, we have seen this too. This is reported to PepperOne (the maintainer of the DB - we are only filling the content). Hope they will fix this in one-two days
This is fixed now. You can go
This is fixed now. You can go to ZDDX folder and run UpdateXMLs.sh script to update the database.
rabing
After running "UpdateXMLs.sh"
Post by rabing »
After running "UpdateXMLs.sh" there are 251xml files with the wrong URL and 29 xml files are OK:
root@rpi1:/opt/z-way-server/ZDDX# fgrep "deviceImage url" * | grep zwavedevlib/ | wc -l
251
root@rpi1:/opt/z-way-server/ZDDX# fgrep "deviceImage url" * | grep pepper | wc -l
29
Indeed! We have submitted a
Indeed! We have submitted a bug report to PepperOne.
Pitt13
New Update
Post by Pitt13 »
Hello, I am French, when we could interface with the ability to create scenes? The top would be kind Zipabox or home center 2 for beginners like me: D possibiliter to create virtual buttons, block temporisation.etc ...
thank you
Pitt13
Pitt13
bririv
not working
Post by bririv »
This doesn't work for me - I can't get the security interview to pass, even by using Force as you suggest. I even bought a new RF card for my lock and it gets stuck in the final stage of the interview. I have removed and added the lock several times, and even put the z-stick right next to the lock and tried the interview process from there. Nothing is working and I'm stuck.
woggwoo
Schlage locks
Post by woggwoo »
I too would like to know if the z-wave line of Schlage locks is now supported.
