Z-cloud and razberry
/var/log/z-way-server.log
Marconnaise
Going back to Z-way
hi, i have installed Z-cloud and shut-down the z-way server. How do i get back to z-way. I tried this in ssh:
cd /opt/z-way-server
sudo bash
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/z-way-server/libs
./z-way-server
and it worked, but when i close the terminal window, no more access to rasperrypi:8083.
Thanks very much.
sudo bash
./z-way-server
Thanks very much.
do /etc/init.d/Z-Way start
or restart your RPi (it should start automatically)
t2tonesimone
Plugging a dongle to get 2 sticks on same network?
Polto I understand from your comment that I could have a local version of Z-way running using the razberry board and at the same time a version of z-cloud running using an usb stick or is this me misreading you comment above? If I were to go about doing this would I need to configure the usb stick as a secondary controller and would I need to associate devices with it? (I think not because I dont think I can associate with 2 devices?) Will this then allow me to have in effect 2 instances running simultaniously Z-Way and Z-Cloud allowing both local and remote access?
Yes, you can use both at the
Yes, you can use both at the same time. Just include the second in as secondary controller
