You should first enable remote access in the configuration portal (on port 8084).
You will be assigned a box id and can set password there.
Can't access to 8084 port v1.7.0
Re: Can't access to 8084 port v1.7.0
I cannot see nothing there. It could be due to the fact that apache is working on door 80?
but why it is necessary to remove apache server? is there any way to have door 8084 working keeping apache as it is?Flo5929 wrote: After reinstalling 1.7.0 and removing the apache server I had installed (on port 80), a page load on the 8084 port
Dunno, I don't have a RaspberrySolarFlor wrote:but why it is necessary to remove apache server? is there any way to have door 8084 working keeping apache as it is?Flo5929 wrote: After reinstalling 1.7.0 and removing the apache server I had installed (on port 80), a page load on the 8084 port
You'd better wait for @PoltoS to reply.
Hm... just noticed that our 8084 service also uses /var/www/ folder, so it might conflict with apache. No need to remove apache - just configure one of them to move in a neighboring folder. I'll put it in our todo list to change in future.
How?PoltoS wrote:just configure one of them to move in a neighboring folder.
thanks for your help
You can change it /etc/apache/sites-enabled/*default*
When I said that I had access to a page that asked me a login and password, it was like with a htaccess.PoltoS wrote:first time it asks you to specify a password. this is ok
As mentioned above, it's a conflict with the /var/www folder.
Now everything works fine.
Thank you for your help.
What do you mean exactly? have you changed the default folder for apache?Flo5929 wrote: As mentioned above, it's a conflict with the /var/www folder.
I'm worried to change it bevause I have a softaware working on it.
Please give more details
Any estimation for that?PoltoS wrote: I'll put it in our todo list to change in future.
