Vision ZD2102EU-5 inclusion problems
Re: Vision ZD2102EU-5 inclusion problems
Bad news, since I was planning to buy some of those. (I do have one of the older modules, that works fine)
Wow-wow, wait a moment! If it is only Basic CC not passing the interview, it shouldn't affect any other command classes at all. It should be still visible in the UI, showing Battery status, etc.thaui wrote:This means zd2102EU-5 is not compatible with zway because i can not see it in the UI and the battery status is contantly at 0%. The sensor can not be used anyway. But many thanks for your reply.
If it is not, then try requesting battery level from JS, for example:
http://ip:8083/ZWaveAPI/Run/devices[5].Battery.Get()
I have seen battery reports in your log, so I think it should generally work.
yes I can see the battery status of the Gen 5 sensor showing 0% (Should be 100%) It's not working at all but the request http://ip:8083/ZWaveAPI/Run/devices[5].Battery.Get() was send to the controller.
So the verdict is that it is the device from Vision is at fault?
Mine is not working at all Basic.Get() and Battery.Get() returns only null
This is actually fine, because requests are asynchronous. Calling .Get() just places requests in queue, but they are actually delivered to device when it wakes up. As there's no clue when device will actually wake up (it could take hours or even days), there's no reason to return anything, so it returns null.bcaroll wrote:Mine is not working at all Basic.Get() and Battery.Get() returns only null
http://192.168.0.103:8083/ZWaveAPI/Run/ ... [43].Basic
{"name":"Basic","data":{"invalidateTime":1428319011,"updateTime":1426791908,"type":"empty","value":null,"supported":{"invalidateTime":1428319011,"updateTime":1426791908,"type":"bool","value":true},"version":{"invalidateTime":1428319011,"updateTime":1426791911,"type":"int","value":1},"security":{"invalidateTime":1426791907,"updateTime":1426791909,"type":"bool","value":true},"interviewDone":{"invalidateTime":1426791907,"updateTime":1426797642,"type":"bool","value":false},"interviewCounter":{"invalidateTime":1426791907,"updateTime":1426797642,"type":"int","value":0},"level":{"invalidateTime":1428319011,"updateTime":1426791908,"type":"empty","value":null}},"id":32}
http://192.168.0.103:8083/ZWaveAPI/Run/ ... 3].Battery
{"name":"Battery","data":{"invalidateTime":1428318205,"updateTime":1426791908,"type":"empty","value":null,"supported":{"invalidateTime":1428318205,"updateTime":1426791908,"type":"bool","value":true},"version":{"invalidateTime":1428318205,"updateTime":1426791913,"type":"int","value":1},"security":{"invalidateTime":1426791907,"updateTime":1426791909,"type":"bool","value":true},"interviewDone":{"invalidateTime":1426791907,"updateTime":1426791921,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1426791907,"updateTime":1426791920,"type":"int","value":9},"lastChange":{"invalidateTime":1428318205,"updateTime":1426791921,"type":"int","value":1426791921},"history":{"invalidateTime":1428318205,"updateTime":1426791921,"type":"empty","value":null,"100":{"invalidateTime":1428318205,"updateTime":1426791921,"type":"int","value":1426791921},"0":{"invalidateTime":1428318205,"updateTime":1428318583,"type":"int","value":1428318583}},"last":{"invalidateTime":1428318205,"updateTime":1428318583,"type":"int","value":0}},"id":128}
Okay i will exclude the device and include it again. Let you know if it will work. Until now this is the reason why i have not bought further gen5 zd2102 sensors.
I have excluded and re-included the ZD2102-EU-5 and I can now confirm this device isn't working correctly. The interview was made now to 100% with RC24. It does not appear in the HA GUI and is also not shown as a device. Only the battery is shown in the HA GUI. Same behaviour than before. This device will not work.
Yep, we added a workaround for Secure Basic (which is not clearly documented in the standard) in rc24, so it should pass the interview now with new Vision and Aeon devices.
As of Battery CC, looks like the value is up to date. So the device really reports it, but the value is wrong sometimes – firmware problem, I guess. I can only tell by the attached log, but it is outdated now.
Shall I post you the actual config file done with rc24?
