enocean integration - how?
Re: enocean integration - how?
You need the dongle and devices. nothing more. Go to devices and include EnOcean device using this (first add EnOcean binding with correct port)
Anyone out there who can share some Enocean experiences with us? Curious to know which devices are being supported/used. Also reliability reports would be interesting. The technology used to have a negative reputation, but I do no read much about that lately.
So who kicks the ball?
Ok,
have integrated the EnOcean Pi module - https://www.enocean.com/en/enocean-pi/
Before have updated my Z-Way to version 2.1.1.
EnOcean module should be added as ttyAMA0 device in configuration - all fine.
Add devices - EnOcean, it is userfriendly - you can choose the manufacturer and then the device.
Next step is "learn" - adn this should be all.
My Window/Door sensor (Hoppe) is not in database - the only devce I wanted to include
http://www.hoppe.com/in/en/window-handl ... secusignal
There must be 3 states:
Open
Closed
Semi-Open
I get value change for
closed D0
open E0 (from semi -> open), C0 (from closed -> open)
semi open F0
code change seems to be here:
55 00 07 07 01 7A F6 D0
I hope this are all information for an integration
Best regards
Michael
Open
Closed
Semi-Open
closed D0
semi open F0
[2015-09-05 13:04:41.644] [I] [zeno] RECEIVED: ( 55 00 07 07 01 7A F6 C0 01 8E 56 0D 20 02 FF FF FF FF 3D 00 FB )
[2015-09-05 13:04:41.645] [I] [zeno] Got telegram: rorg = 0xf6, sender = 0x0d568e01, size = 1, status = 32
[2015-09-05 13:04:41.645] [D] [zeno] SETDATA controller.data.promiscLastSeen = "0d568e01"
[2015-09-05 13:04:42.233] [I] [zeno] RECEIVED: ( 55 00 07 07 01 7A F6 F0 01 8E 56 0D 20 02 FF FF FF FF 37 00 F8 )
[2015-09-05 13:04:42.234] [I] [zeno] Got telegram: rorg = 0xf6, sender = 0x0d568e01, size = 1, status = 32
[2015-09-05 13:04:42.234] [D] [zeno] SETDATA controller.data.promiscLastSeen = "0d568e01"
[2015-09-05 13:04:42.692] [I] [zeno] RECEIVED: ( 55 00 07 07 01 7A F6 E0 01 8E 56 0D 20 02 FF FF FF FF 3A 00 6E )
[2015-09-05 13:04:42.693] [I] [zeno] Got telegram: rorg = 0xf6, sender = 0x0d568e01, size = 1, status = 32
[2015-09-05 13:04:42.693] [D] [zeno] SETDATA controller.data.promiscLastSeen = "0d568e01"
[2015-09-05 13:04:43.047] [I] [zeno] RECEIVED: ( 55 00 07 07 01 7A F6 D0 01 8E 56 0D 20 02 FF FF FF FF 44 00 9B )
[2015-09-05 13:04:43.048] [I] [zeno] Got telegram: rorg = 0xf6, sender = 0x0d568e01, size = 1, status = 32
[2015-09-05 13:04:43.048] [D] [zeno] SETDATA controller.data.promiscLastSeen = "0d568e01"
[2015-09-05 13:04:43.286] [I] [zeno] RECEIVED: ( 55 00 07 07 01 7A F6 C0 01 8E 56 0D 20 02 FF FF FF FF 33 00 2D )
[2015-09-05 13:04:43.287] [I] [zeno] Got telegram: rorg = 0xf6, sender = 0x0d568e01, size = 1, status = 32
[2015-09-05 13:04:43.287] [D] [zeno] SETDATA controller.data.promiscLastSeen = "0d568e01"
Best regards
Michael
Thanks for giving this first impression
Can someone help me regarding this post:
Best Regards,
Bernhard
I have the EnOcean usb-dongle connected to my Pi, but how do I add EnOcean binding with correct port? Is there a way to do this in smarthome-ui? Currently the UI shows no option to connect EnoOcean-Devices which seems to be correct according the changelogs.PoltoS wrote:You need the dongle and devices. nothing more. Go to devices and include EnOcean device using this (first add EnOcean binding with correct port)
Best Regards,
Bernhard
Did you add the Enocean network app? (It is under the local apps)
Ah, thats the trick
Many thanks!
