Webif is switch off
bogr
Re: Webif is switch off
Post by bogr »
Try to create the file, as PoltoS suggested then, e.g.:
pi@raspberrypi echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json
Sparkacus
Post by Sparkacus »
bogr wrote:Try to create the file, as PoltoS suggested then, e.g.:
Perfect, yup that did the trick.
Thank you
gmccarthy
Post by gmccarthy »
I'm getting this error as well after a failed upgrade. Unable to connect on port 8084.
I've tried creating the file above but it has no effect. Restarted the Pi and will getting the same error.
How do I resolve this error?
Error logs if it helps:
http://pastebin.com/EWZqU25X
Last error:
[2016-03-05 14:04:57.615] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
Update: Fixed the issue - reinstalled software. Not sure why it went wonky.
wget -q -O - http://razberry.z-wave.me/install | sudo bash
NanoBot
Post by NanoBot »
Would someone please help me with pulling up the page that has the Expert UI settings?
I am having the same problem as others regarding the Webif upgrade... thank you
How do I do this?
Expert UI -> Settings -> Management -> Firmware update -> Update to latest
NanoBot
Post by NanoBot »
PoltoS wrote:Please got to Z-Way->Setings->Management->Firmware upgrade. Once you close the popup, webif closes back. his was done for security reasons. You can also enable it using shell (in case of troubles with Z-Way):
Write time to open 8084 in it (in seconds).
When I enter the above the following is what I get:
pi@raspberrypi:~ $ /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json
bash: /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json: No such file or directory
Would you please let me know what I'm doing wrong?
I am trying to correct the issue with following error:
" Webif is switched off. You can switch it on from Z-Way UI or box shell"
Thank you.[/quote]
It should be
NanoBot
Post by NanoBot »
PoltoS;
When I enter the command you sent below; i receive a "Permission denied" error... see below... please let me know what I'm doing wrong... thank you...
bash: /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json: Permission denied
Did you try with sudo?
sudo echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json
NanoBot
Post by NanoBot »
Yes, I tried it with psudo as follows ... same results... Permission denied.... see below
pi@raspberrypi:~ $ sudo echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json
bogr
Post by bogr »
That's really strange, but maybe the permissions got screwed up somehow. Check the permissions:
ls -l /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json
That should show you that at least the user (root) has +w.
