Rasberry PI 3 supported?
chatchat
Re: Rasberry PI 3 supported?
Post by chatchat »
@rabing, where to find "raspi-config" -> 8. "Advanced Options" -> "Device Tree" ?
I'm using Jeedom...
raspi-config is a basic command line instruction via the console of raspberrypi. Nothing to do with Zway or Jeedom
BrammiX
Post by BrammiX »
chatchat wrote:@rabing, where to find "raspi-config" -> 8. "Advanced Options" -> "Device Tree" ?
I'm using Jeedom...
Thanks, this solved my problem using Domoticz
Gr33nG081
Post by Gr33nG081 »
The solution by rabing is also working for me. I disabled the device tree with the raspi-config and now the RaZberry is connected. Thanks!
For me it's not a problem that te bluetooth and wifi wont work.
Dear customers,
Looks like Pi 3 uses UART for Bluetooth. We will investigate this once we have the board in hands (next week).
Meanwhile have a look here:
http://www.briandorey.com/post/Raspberr ... Workaround
We think we will disable BT by default and keep WiFi. Those who will need BT will have to slow down the CPU (not sure yet if this is stable enough)
nochkin
Post by nochkin »
If you are fine with Bluetooth disabled but want to have WiFi operational anyway, you can do the following (must be root or use sudo):
1. Make sure you are on the latest kernel and have the latest overlay files:
rpi-update
2. Add "disable BT" overlay:
echo "dtoverlay=pi3-disable-bt" >> /boot/config.txt
3. Restart the server:
reboot
Mephix
Post by Mephix »
Thanks nochkin!
I just tried your suggestion and it works perfectly fine.. both Razberry and Wifi. I don't plan to use BT for now so this is great.
ben52456j13
Post by ben52456j13 »
great solution, I also work it working with bluetooth disabled. :D
We have updated the install script to automatically disable Bluetooth during install/upgrade.
kernel-z
Post by kernel-z »
i'm having the same issue. i did the edit in config.txt.
how can i see that bluetooth is now really disabled from command line ?
also i saw that on internet and would like to apply it :
http://www.vesternet.com/resources/appl ... vfFOdDl-2k
but the file called 09-tty.rules doesn't exist why ?
ps: i plan to use the zwave module using openzwave not using the zwave install with website
