Hi is there a fix for this issue.
I have installed many times on raspberry PI 3 board. it worked the first install but now will not allow me to login to 8083 or 8084
really I'm starting to wonder why use this device if its not dependable
also it seems that no one has posted a resolution
Can't login using https://find.z-wave.me
Re: Can't login using https://find.z-wave.me
There are many different problems discussed in this topic, so please give us an idea about your problem. Do you try to use browser or some mobile app to login? what do you enter as login?
Hi!
I am facing the same problem.
When trying to log in via https://find.z-wave.me with Remot ID and PW i get "Remote access not possible or wrong password".
IOS App is fine.
In the end I am a little bit puzzled if I usw the right password.
I also found no way to change the Remote Access password. Is there a way?
Thanks!
IOS App is fine.
Thanks!
You have to use "RemoteID/admin" as login and use your Z-Way admin password.
You can also log in as any other user defined in Z-Way, not only admin
Is the remote ID the access ID in Z-Wave>Me Dashboard - Remote Access? and the same password to log on locally?PoltoS wrote:You have to use "RemoteID/admin" as login and use your Z-Way admin password.
Can't log on with find.z-wave or z-way app on android. Locally I have access to the dashboard!
Help please, thank you
Please send us on support@z-wave.me your login and id and we will check it
Hi, I'm a noobie here.. apologies for asking the same question.
May I know if anyone still faces the same problem? I'm using RPi 3, I can log in using http://192.168.*.*:8083. However, I am unable to log in using the find.zwave.me. I have enabled remote access.
I have also tried downloading the Android app, and am also unable to log in. May I know if there's any way to reset the remote password? Would the password for remote login be the same as that for the local login?
Thanks much for any help!
Hi, I have the same problem, I can´t acces. I try with the same ID and pass and not work, and I try with the number ID, and I have the same message. Remote access not possible or wrong password.
Thanks!!
Thanks!!
I find the solution.
ID(number)/admin(or name of user)
Same Pass
Working.
Same Pass
Working.
I've tried this as well, but it doesn't work for me.000 wrote:I find the solution.
Same Pass
Working.
