RESOLVED Z-uno doesn't appear in serial ports
Re: RESOLVED Z-uno doesn't appear in serial ports
If you have TeamViewer I can look it myself. Just write me PM with TeamViewer login / psw.
I re-compiled and tried to upload "SimpleDimmer" example resulting in error.
Here is the content of log file "uCxx-2016-10-18":
DEBUG [2016-10-18 19:02:21,806]
Starting on Windows.
ARGS:C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1\compiler.exe build C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp/SimpleDimmer.cpp -r C:\Users\Gast\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.6
VERSION:0.90b1 MD5:3550b8410dd9d22ddcee5293d31113d5 MY_FULLNAME:C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/compiler.exe g_base:None
DEBUG [2016-10-18 19:02:21,812] buildFunc
INFO [2016-10-18 19:02:22,802] --- Script path: C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1 SDCC_PATH:C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/
INFO [2016-10-18 19:02:22,805]
INFO [2016-10-18 19:02:23,200]
Preprocessing file: C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Print.cpp with SDCPP...
INFO [2016-10-18 19:02:23,318]
INFO [2016-10-18 19:02:23,319] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Print_sdcpp_.cpp ...
INFO [2016-10-18 19:02:23,625]
Preprocessing file: C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Stream.cpp with SDCPP...
INFO [2016-10-18 19:02:23,664]
INFO [2016-10-18 19:02:23,664] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Stream_sdcpp_.cpp ...
INFO [2016-10-18 19:02:24,045]
Preprocessing file: C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HardwareSerial.cpp with SDCPP...
INFO [2016-10-18 19:02:24,072]
INFO [2016-10-18 19:02:24,072] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HardwareSerial_sdcpp_.cpp ...
INFO [2016-10-18 19:02:24,325]
Preprocessing file: C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HLCore.cpp with SDCPP...
INFO [2016-10-18 19:02:24,374]
INFO [2016-10-18 19:02:24,374] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HLCore_sdcpp_.cpp ...
INFO [2016-10-18 19:02:24,628]
Preprocessing file: C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\_SimpleDimmer.cpp with SDCPP...
INFO [2016-10-18 19:02:24,657]
INFO [2016-10-18 19:02:24,658] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\_SimpleDimmer_sdcpp_.cpp ...
INFO [2016-10-18 19:02:24,871]
INFO [2016-10-18 19:02:24,898]
INFO [2016-10-18 19:02:24,898] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Print_sdcpp_.cpp ...
INFO [2016-10-18 19:02:25,098]
INFO [2016-10-18 19:02:25,125]
INFO [2016-10-18 19:02:25,125] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Stream_sdcpp_.cpp ...
INFO [2016-10-18 19:02:25,365]
INFO [2016-10-18 19:02:25,391]
INFO [2016-10-18 19:02:25,391] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HardwareSerial_sdcpp_.cpp ...
INFO [2016-10-18 19:02:25,582]
INFO [2016-10-18 19:02:25,611]
INFO [2016-10-18 19:02:25,611] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HLCore_sdcpp_.cpp ...
INFO [2016-10-18 19:02:25,842]
INFO [2016-10-18 19:02:25,871]
INFO [2016-10-18 19:02:25,872] Compiling C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\_SimpleDimmer_sdcpp_.cpp ...
INFO [2016-10-18 19:02:26,072] Compiling file "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\LLCore_arduino.c" by means of SDCC...
INFO [2016-10-18 19:02:26,644] sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\LLCore_arduino.c"
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051.exe -plosgffw "LLCore_arduino.rel" "LLCore_arduino".asm
at 1: warning 119: don't know what to do with file ''. file extension unsupported
C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\LLCore_arduino.c:25: warning 85: in function NOPS unreferenced function argument : 'i'
C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\LLCore_arduino.c:208: warning 85: in function delayMicroseconds unreferenced function argument : 'value'
INFO [2016-10-18 19:02:26,644] Compiling file "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Print_ucxx.c" by means of SDCC...
INFO [2016-10-18 19:02:26,825] sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Print_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Print_ucxx.rel" "Print_ucxx".asm
INFO [2016-10-18 19:02:26,825] Compiling file "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Stream_ucxx.c" by means of SDCC...
INFO [2016-10-18 19:02:27,055] sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\Stream_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Stream_ucxx.rel" "Stream_ucxx".asm
INFO [2016-10-18 19:02:27,055] Compiling file "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HardwareSerial_ucxx.c" by means of SDCC...
INFO [2016-10-18 19:02:27,239] sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HardwareSerial_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HardwareSerial_ucxx.rel" "HardwareSerial_ucxx".asm
INFO [2016-10-18 19:02:27,240] Compiling file "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HLCore_ucxx.c" by means of SDCC...
INFO [2016-10-18 19:02:27,492] sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\HLCore_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HLCore_ucxx.rel" "HLCore_ucxx".asm
INFO [2016-10-18 19:02:27,493] Compiling file "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\_SimpleDimmer_ucxx.c" by means of SDCC...
INFO [2016-10-18 19:02:27,687] sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp\_SimpleDimmer_ucxx.c"
sdcc: sdas8051.exe -plosgffw "_SimpleDimmer_ucxx.rel" "_SimpleDimmer_ucxx".asm
INFO [2016-10-18 19:02:28,115] sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp/main.c"
sdcc: sdas8051.exe -plosgffw "main.rel" "main".asm
sdcc: Calling linker...
sdcc: sdld.exe -nf "main.lk"
INFO [2016-10-18 19:02:28,115] Making firmware file: C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp/SimpleDimmer-0206.hex ...
INFO [2016-10-18 19:02:28,177] packihx: read 141 lines, wrote 263: OK.
INFO [2016-10-18 19:02:28,177] [Done]
Elapsed:5.3710000515 s
INFO [2016-10-18 19:02:28,188]
DEBUG [2016-10-18 19:02:29,332]
ARGS:C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1\compiler.exe size C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp/SimpleDimmer.cpp
DEBUG [2016-10-18 19:02:29,338] sizeFunc
INFO [2016-10-18 19:02:29,338]
DEBUG [2016-10-18 19:02:29,717]
ARGS:C:\Users\Gast\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1\compiler.exe prog C:\Users\Gast\AppData\Local\Temp\build1385311564343462029.tmp/SimpleDimmer.cpp -d COM1 -fr EU --param sec=0 --param mcmd=0
INFO [2016-10-18 19:02:29,724] Status: Openning port
INFO [2016-10-18 19:02:29,726] Status: Stoping the user code
DEBUG [2016-10-18 19:02:29,726] >> 01 04 00 08 02 F1
INFO [2016-10-18 19:02:30,230] Status: Closing port
INFO [2016-10-18 19:02:30,232] Status: Openning port
DEBUG [2016-10-18 19:02:30,236] >> 01 08 00 2A FF FF FF 00 10 32
ERROR [2016-10-18 19:02:36,237] 0 Unknown exception "list index out of range"
ERROR [2016-10-18 19:02:36,237] list index out of range
You mean that you do not see it under serial ports in computer management more?carlo wrote: and since then the z-uno is not recognized anymore by my pc in any way, also not after putting in rescue mode. I tried several usb ports, ...
In this case retry the rescue mode...
"hold down the Service Button and then hold down the Reset button, wait for a second, release the Reset button then release the Service Button"
take care that you made the right direction.
Michael
Yes, that is what I mean. Initially I had a COM device called UZB on COM21 that I selected to upload my first sketch to. Now, after 1 successful upload of the example sketch 'SimpleDimmer', this UZB device on COM21 is not available anymore, also not after multiple attempts to put the z-uno in rescue mode. When I put the z-uno in rescue mode, the sketch code in the z-uno stops running which I deduct from the fact that the dimmer does not respond anymore to commands. Still the z-uno is not recognized as UZB on COM21. Only COM1 is available and uploading to COM1 results in error as can be seen in log file content in my previous post.
I also de-installed and re-installed the windows UZB driver as provided by z-uno project using the 'hdwwiz' command line tool in windows. When re-installed I get the message that the device might not be working properly because of a code 10 "Device does not start"
ok,... you can try a full factory reset:
Long press service (until red LED will flash) then 3 x press short the same button.
Sketch will be erased - but Z-Uno should come back.
I need it very very rare.... only in special situations....
Michael
Michael
Michael, thanks a lot
PROBLEM SOLVED
PROBLEM SOLVED
