Compatibility with Fibaro HC2 - Problem Corrected
04greg1980
Re: Compatibility with Fibaro HC2
Post by 04greg1980 »
Thanks for your answer and for the work.
I will wait the update.
See you soon
Greg
valyHD
Post by valyHD »
Hello, I have exactly the same problem like greg. Do anyone solved this?
04greg1980
The new version (2.0.7) has not change anything for me.
I can't use z-uno with my hc2, too.
I hope the next version will be the good one.
See you soon
Greg
Hve you tried param 12? http://z-uno.z-wave.me/z-wave/configuration-parameters/
What is not working for you?
04greg1980
I don't know how i can change the parameter #12 to 1.
Have you an exemple of code?
Thanks a lot
Greg
Do it from Fibaro UI
veuchez
Post by veuchez »
Good morning,
I see with this script on HC2 11 motion sensors and 11 door sensors.
It's normal? I expected to see only 10 door sensors.
Thank you!
11 is normal - 1 for root device + 10 for channels. But why do you see motion? No idea?
veuchez
Post by veuchez »
I do not know ... Maybe we need to change any parameter ... Maybe something wrong in the configuration parameters in the Arduino IDE program?
04greg1980
Could you give me your configuration into arduino IDE? Could you send me your arduino file?
Because for me I have only one motion sensor and one door sensor only visible into Fibaro interface.
I have tried to put 1 in the #12 parameter, but nothing change for me.
I'm in 4.110 version of the fibaro. Please help me!
Thanks a lot.
Greg
