Device stops working - new interview required
CudaNet
Re: Device stops working - new interview required
Post by CudaNet »
Thanks pz1 for opening the issue on Git. Now we need a 2.2.6 that addresses the loss of z-wave control ASAP. Allow me to write the release notes.
2.2.6 Corrects issue with having to re-interview specific z-wave devices.
000
Post by 000 »
CudaNet wrote:Thanks pz1 for opening the issue on Git. Now we need a 2.2.6 that addresses the loss of z-wave control ASAP. Allow me to write the release notes.
CudaNet, I do an upgrade, but the actual version is 2,2,5, is already public the 2,2,6?
Thank you!!
I don't expect a 2.2.6. They seem to be working on 2.3.0 now. It is not advisable to try any of the present 2.3 release candidates. A lot of code is still changing as far as I can see.
CudaNet
Post by CudaNet »
Greatness ? Looks as if 2.3.0 is now official with release notes. Can anyone confirm that this release alleviates the issue (as defined within this thread) ? Much appreciate any feedback.
v2.3.0 is out!
roha
Post by roha »
I've just upgraded. Fingers crossed.
roha
Post by roha »
Upgrade done - this time without issues.
the good: my fibaro motion sensors still work.
the bad: nothing seem changed regarding the interview problem :(
jarnold
Post by jarnold »
Still getting the problem after using the ExpertUI and returning to the Razberry main menue. The device I have worked on is lost.
Can you give more info about the issue?
roha
Post by roha »
So, after using 2.3.0 for some time now, I have to say that it is indeed a lot more stable regarding this issue. It was not necessary for me to do the often interviews again.
Once thing I do notice is that the status of the actors often are not updated properly. This caused me some issues as I had the "Don't send On command, if device is already turned On, similarly for Off" flag enabled in a lot scenes. Since I have disabled the flag it became a lot more reliable. So, thanks a lot for that!
Cheers,
Robert
