How to load older FW version
Pmant
Re: How to load older FW version
Post by Pmant »
Willem_K wrote:After upgrade of my UZB to firmware 5.07 it is not working anymore, the stick is recognised but adding nodes is not possible, it causes a crash and I have to a restart it. What can I do to 'revive' it?
Same here, Stick seems to crash and reboot everytime I want to add a node or do something else with it. It also crashes randomly when doing nothing. Tested on windows pc and Raspberry PI.
Pmant
Post by Pmant »
Now I can't update the firmware at all, the request to your update server gives this response:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND (type != 'bootloader' OR targetBootloaderCRC != ) AND enabled = 'enabled' ' at line 1
https://service.z-wave.me/expertui/uzb/ ... ionMinor=7
Z-Wave Support
Post by Z-Wave Support »
The problem is under investigation.
Z-Wave Support
The problem with update server was fixed. Thanks for pointing to it
Could yu give us more info. log, controller info page screenshot, detailed description what do you mean by dongle crash
Pmant
Post by Pmant »
Answering the Support Mail: I had to switch back to EU frequency after the Update to "Update firmware to 2 channels (EU/RU/US/ANZ/MY/IL/..) on 05.07". I think it was on "JP" which seems to be the other firmware option.
Also I noticed when upgrading to "Update firmware to 2 channels (EU/RU/US/ANZ/MY/IL/..) on 05.07" both upgrade buttons started the upgrade animation. And the Server returns the same fileURL for both options (2 and 3 Channel):
   "data":[
         "id":"98",
         "baseid":"",
         "enabled":"enabled",
         "type":"bootloader",
         "file":"bin",
         "vendorID":"277",
         "bootloaderCRC":null,
         "appVersionMajor":"5",
         "appVersionMinor":"7",
         "targetBootloaderCRC":"29304",
         "targetAppVersionMajor":null,
         "targetAppVersionMinor":null,
         "fileURL":"bootloader_UZB_from_05_07_to_7278_2MB.bin",
         "released":"2017-05-12",
         "comment":"Update bootloader to 7278",
         "position":"72",
         "version":"5.7"
         "id":"88",
         "baseid":"",
         "type":"firmware",
         "file":"bin",
         "vendorID":"277",
         "targetBootloaderCRC":null,
         "targetAppVersionMajor":"5",
         "targetAppVersionMinor":"7",
         "fileURL":"UPD_FIRMWARE_UZB500_X_from05_07_to_UZB500_3CH_05_07.bin",
         "released":"2017-04-18",
         "comment":"Update firmware to 3 channels (JP\/TW\/KR\/SG) on 5.07",
         "position":"57",
         "version":"5.7"
         "id":"89",
         "baseid":"",
         "type":"firmware",
         "file":"bin",
         "vendorID":"277",
         "comment":"Update firmware to 2 channels (EU\/RU\/US\/ANZ\/MY\/IL\/..) on 05.07",
         "position":"58",
         "version":"5.7"
On Raspberry PI:
Dongle is recognized and initialized correctly with both Z-Way and OpenZWave (dev/ttyACM0). As soon as I want to include or exclude a node the dongle gets disconnected and reconnected to ttyACM1. Next time ttyACM2 and so on.
On Windows:
I can hear the USB-Disconnect/Connect Sounds whenever I want to include or exclude a node. COM-Port stays the same but I need to restart the Software.
Log:
[2017-05-15 14:19:35.656] [I] [zway] Adding job: Remove node from network
[2017-05-15 14:19:35.670] [I] [zway] Job 0x4b (Remove node from network): Ready to remove - push button on the device to be removed
[2017-05-15 14:19:38.367] [C] [i/o] Device I/O error: Das Gerät erkennt den Befehl nicht.
[2017-05-15 14:19:38.367] [E] [zway] Device processing interrupted
[2017-05-15 14:19:38.375] [I] [core] Terminating Z-Wave binding
[2017-05-15 14:19:38.375] [I] [zway] Saving configuration data to config/zddx/c8217646-DevicesData.xml
[2017-05-15 14:19:48.376] [I] [core] Restarting Z-Wave binding
[2017-05-15 14:19:48.395] [I] [zway] Adding job: Get controller info and supported function classes
[2017-05-15 14:19:48.417] [I] [zway] Adding job: Get or set Z-Wave.Me firmware capabilities
[2017-05-15 14:19:48.417] [I] [zway] Adding job: Set Serial API timeouts
[2017-05-15 14:19:48.417] [I] [zway] Adding job: Set RF power level
[2017-05-15 14:19:48.417] [I] [zway] Adding job: WatchDog Start
[2017-05-15 14:19:48.417] [I] [zway] Adding job: Change/Get Z-Wave.Me firmware frequency
[2017-05-15 14:19:48.417] [I] [zway] Adding job: Get home id and controller node id
[2017-05-15 14:19:48.417] [I] [zway] Removing job: Get controller info and supported function classes
[2017-05-15 14:19:48.427] [W] [zway] Received SOF, while awaiting ACK
[2017-05-15 14:19:48.428] [W] [zway] No job of class 0x0a is waiting for callback 0x03
[2017-05-15 14:19:48.428] [I] [zway] Unhandled callback for function 0x00
[2017-05-15 14:19:48.428] [I] [zway] Removing job: Unknown function class
[2017-05-15 14:19:48.458] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): In progress
[2017-05-15 14:19:48.469] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): Done
[2017-05-15 14:19:48.469] [I] [zway] Removing job: Get or set Z-Wave.Me firmware capabilities
[2017-05-15 14:19:48.480] [I] [zway] Job 0x06 (Set Serial API timeouts): Old timeouts are: ACK timeout 1500 ms and Byte timeout 150 ms
[2017-05-15 14:19:48.480] [I] [zway] Removing job: Set Serial API timeouts
[2017-05-15 14:19:48.491] [I] [zway] Job 0x17 (Set RF power level): Done
[2017-05-15 14:19:48.491] [I] [zway] Removing job: Set RF power level
[2017-05-15 14:19:48.502] [I] [zway] Removing job: WatchDog Start
[2017-05-15 14:19:48.524] [I] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): Done
[2017-05-15 14:19:48.524] [I] [zway] Removing job: Change/Get Z-Wave.Me firmware frequency
[2017-05-15 14:19:48.535] [I] [zway] Job 0x20 (Get home id and controller node id): Home id: 0xc8217646, controller node id: 1
[2017-05-15 14:19:48.535] [I] [zway] Adding job: Get controller capabilities
[2017-05-15 14:19:48.535] [I] [zway] Adding job: Get controller version
[2017-05-15 14:19:48.535] [I] [zway] Adding job: Get SUC node id
[2017-05-15 14:19:48.535] [I] [zway] Adding job: Get initial data about network devices
[2017-05-15 14:19:48.535] [I] [zway] Adding job: Read bytes from extended EEPROM
[2017-05-15 14:19:48.535] [I] [zway] Removing job: Get home id and controller node id
[2017-05-15 14:19:48.546] [I] [zway] Removing job: Get controller capabilities
[2017-05-15 14:19:48.558] [I] [zway] Removing job: Get controller version
[2017-05-15 14:19:48.569] [I] [zway] Job 0x56 (Get SUC node id): SUC node is 1
[2017-05-15 14:19:48.569] [I] [zway] Removing job: Get SUC node id
[2017-05-15 14:19:48.665] [I] [zway] Adding job: Get node protocol information
[2017-05-15 14:19:48.665] [I] [zway] Adding job: Get routing table line
[2017-05-15 14:19:48.665] [I] [zway] Loading configuration data from config/zddx/c8217646-DevicesData.xml
[2017-05-15 14:19:48.670] [W] [zway] CC "MultiCmd" is not implemented
[2017-05-15 14:19:48.670] [W] [zway] CC "Security" is not implemented
[2017-05-15 14:19:48.670] [W] [zway] CC "CRC16" is not implemented
[2017-05-15 14:19:48.670] [I] [zway] Adding job: Set controller node information frame
[2017-05-15 14:19:48.670] [I] [zway] Loading Command Classes for device 1
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC Basic
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC ApplicationStatus
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC SwitchBinary
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC SwitchMultilevel
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC SceneActivation
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC ClimateControlSchedule
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC AssociationGroupInformation
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC DeviceResetLocally
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC CentralScene
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC ZWavePlusInfo
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC MultiChannel
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC ManufacturerSpecific
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC PowerLevel
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC NodeNaming
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC Clock
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC Version
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC Time
[2017-05-15 14:19:48.670] [I] [zway] Node 1:0 supports CC MultiChannelAssociation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:1 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:2 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:3 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:4 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:5 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:6 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:7 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:8 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:9 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:10 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:11 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:12 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:13 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:14 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:15 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:16 supports CC Basic
[2017-05-15 14:19:48.671] [I] [zway] Node 1:1 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:2 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:3 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:4 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:5 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:6 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:7 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:8 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:9 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:10 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:11 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:12 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:13 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:14 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:15 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:16 supports CC SwitchBinary
[2017-05-15 14:19:48.671] [I] [zway] Node 1:1 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:2 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:3 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:4 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:5 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:6 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:7 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:8 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:9 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:10 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:11 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:12 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:13 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:14 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:15 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:16 supports CC SwitchMultilevel
[2017-05-15 14:19:48.671] [I] [zway] Node 1:1 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:2 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:3 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:4 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:5 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:6 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:7 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:8 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:9 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:10 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:11 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:12 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:13 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:14 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:15 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:16 supports CC SceneActivation
[2017-05-15 14:19:48.671] [I] [zway] Node 1:1 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:2 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:3 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:4 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:5 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:6 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:7 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:8 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:9 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:10 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:11 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:12 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:13 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:14 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:15 supports CC CentralScene
[2017-05-15 14:19:48.671] [I] [zway] Node 1:16 supports CC CentralScene
[2017-05-15 14:19:48.672] [I] [zway] Adding job: Get controller capabilities
[2017-05-15 14:19:48.672] [I] [zway] Removing job: Get initial data about network devices
[2017-05-15 14:19:48.688] [I] [zway] Removing job: Read bytes from extended EEPROM
[2017-05-15 14:19:48.699] [I] [zway] Removing job: Get node protocol information
[2017-05-15 14:19:48.710] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 1: [ ]
[2017-05-15 14:19:48.710] [I] [zway] Removing job: Get routing table line
[2017-05-15 14:19:48.721] [I] [zway] Removing job: Set controller node information frame
[2017-05-15 14:19:48.743] [I] [zway] Removing job: Get controller capabilities
Pmant
Post by Pmant »
UPDATE:
After switching to JP frequency it does not crash anymore, so how can I switch back to the EU firmware/frequency?
Willem_K
Post by Willem_K »
I have the same.
I had an e-mail discussion with support and they said my stick is broken...but it cannot be a coincidence that we have the same issues. This should be solved one way or another.
herm
Post by herm »
hi,
have exactly the same problem on my stick ... after upgrade to EU 2 channel 5.07 frequency changed to JP and was not usable anymore.... would be great if there exists some kind of downgrade/reflash procedure ...
herm
Willem_K
Post by Willem_K »
So now there are already 3 people having the same issue with the stick after the upgrade, this is not good.
No solotion proposed yet by z-wave support. I hope they will soon.
