Ok, I haven't used this app yet and I don't know it.
My tool gets the information from http://IP:8083/ZAutomation/api/v1/instances. There in Cron section all jobs are mentioned which are enabled to fire. This section is build up at start of z-way-server. A restart should remove all old tasks.
But generally an app which stops has to remove all tasks which it has created. If it doesn't it is badly programmed.
There's a garbage collection missing in this system.
MxInfo tool collection
Re: MxInfo tool collection
Thanks Piet66
I was hoping for an easy fix !
Thanks for trying to help.
My system has got a bit messy, but too big now to go for a factory reset.
I need to learn a bit more JavaScript programming.
With the info from Mxinfo, I'll try to properly delete the broken Cron Jobs.
I don't mean a factory reset. Only stop and start again the z-way-server service:
On Raspi terminal do:
sudo /etc/init.d/z-way-server stop
sudo /etc/init.d/z-way-server start
Which app were you talking about? From automations page or from the old apps page?
I have no much experience with the new automations functions. But I have the feeling (maybe I'm wrong) that the transformation doesn't always work correctly.
I have restarted, many times. Occasionally a full power on/off cycle.
The old apps page, App called 'Schedule' I have 20 instances set.
I think I also had this issue with rogue Cron jobs running while on 2.3.8
Think i'm passed the point where it will self fix.
I will be looking into writing a JavaScript to delete the rogue Cron Jobs.
I like to play, so it might be fun to try.
Hm,
when I'm right that the task list is build up at start, there must be anyone who adds these tasks again. So such a script wouldn't be a solution.
Perhaps you can
- detect in Mx tools which app instance has created the tasks,
- make a copy of this instance
- and delete the old one?
You can also have a look in http://<ip>:8083/ZAutomation/api/v1/instances/<instance no> if there are any wrong data.
Perhaps you can
