Z-Way v4.0.2 Release
harre
Re: Z-Way v4.0.0 Release
Post by harre »
PoltoS wrote:
10 Nov 2022 01:30
Thanks for reporting us, this was fixed! We will soon make a minor release with a few fixes including this. Meanwhile, you can use a workaround:
http://localhost:8083/ZWaveAPI/Run/for (var d in devices) if (devices[d].MultiCmd) devices[d].MultiCmd.data.supported=false
Once 4.0.1 is here, you can revert it back with true at the end or with a Force Interview
Cool, I have run the command and verified that it is indeed disabled for the devices when using:
http://raspberrypi4:8083/JS/Run/zway.devices
But what does it mean that it is disabled? What is changed? Can you write a short summary what the MultiCmd does?
It glues multiple commands together to save the ether time. It is not used in most new devices. It is not critical, but we will fix it very soon
lanbrown wrote:
10 Nov 2022 01:31
PoltoS wrote:
08 Nov 2022 01:10
What’s new on our roadmap? Zigbee support, integration with Matter gateways and many small improvements with Z-Wave Plus v2.
How will Zigbee support be added? Another module, a new Razberry board or some other method.
Yes, an additional module will be required. While Matter support will not require anything additional.
harre
Post by harre »
PoltoS wrote:
10 Nov 2022 05:45
lanbrown wrote:
10 Nov 2022 01:31
PoltoS wrote:
08 Nov 2022 01:10
Will you release a new razzberry module with Zigbee or just a separate Zigbee module i can add to my existing raspberrypi?
PoltoS wrote:
10 Nov 2022 05:44
Thanks for the explanation, it haven't crashed any now during the night so it looks like the issue for solved.
lanbrown
Post by lanbrown »
PoltoS wrote:
10 Nov 2022 05:45
Can what the form factor of the module be shared? GPIO, USB, etc?
I'm looking at doing a refresh of my z-way systems and looking to move from Raspberry Pi 4B's with PoE modules to Compute Module 4's with an IO board that has PoE integration and UPS capabilities builtin. I'm interested in Zigbee but the form factor would play a part of my decision since there is limited room on cases for the Compute Module 4's.
Both USB and GPIO. Both with external antennas like the RaZberry 7 Pro
markchang
Post by markchang »
A ver y big problem server crash.
How to Maker the workaround for non pro users? I ende to solve It in orden to have heating control up
It is crucial for me
Please use this version: https://storage.z-wave.me/z-way-server/ ... _armhf.deb
This is a hot fix - we will release for everybody on Tuesday after deep tests
harre
Post by harre »
It seems to be working now even when setting MultiCmd back to supported=true.
They are several each second!
However, the log is spammed with these entries:
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.511] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.522] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.534] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.546] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.558] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.570] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.582] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.593] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.605] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.616] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
Nov 14 22:55:35 raspberrypi4 z-way [2022-11-14 22:55:35.627] [I] [zway] Node 36:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
harre
Post by harre »
Logs:
This file is 180MB for logging less than 24hrs:
https://www.dropbox.com/s/2v96rx8ncc4qb ... a.log?dl=0
This log is the same as previous log but just the last 10k lines :)
https://www.dropbox.com/s/48w33lungeal6 ... d.log?dl=0
Locked
