4.1.2 Razberry zw0700 error
otverber
Re: 4.1.2 Razberry zw0700 error
Post by otverber »
Well
Here is more serious problem.
Changed router today with new ip addresses.
The PI persisted to the old ip address and I tried an IP release before booting up again (lan).
Now I cant find the PI trough the old or the new network. therefore cannot ssh either.
is it possible to connect a pc with rj45 direct to the PI?
should I remove the sd card and edit files regarding network settings?
Lost for options here
Best regards
lanbrown
Post by lanbrown »
otverber wrote:
27 Aug 2024 17:59
Well
Best regards
You could connect a PC directly to the Ethernet port of the Pi, but you still won't be able to access it. You would also need to have a DHCP server running on your PC.
You would be better off connecting a monitor, keyboard and mouse to the Pi to figure out what is going on.
@PoltoS
This is exactly why this forum should be read only and only admins and mods can post. This is not an official announcement and there are specific places in this forum for this.
