Export heating control buttons to HA
Re: Export heating control buttons to HA
If you look in the network debug console, you can see commands like this:
/ZAutomation/api/v1/devices/Heating_39/command/schedule?room=null
/ZAutomation/api/v1/devices/Heating_39/command/energySave?room=null
/ZAutomation/api/v1/devices/Heating_39/command/frostProtection?room=null
/ZAutomation/api/v1/devices/Heating_39/command/comfort?room=null
Or for a specific room Id:
/ZAutomation/api/v1/devices/Heating_39/command/comfort?room=3
So here is the JS code:
controller.devices.get("Heating_39").performCommand("comfort", {"room":3})
markchang
Post by markchang »
Ok, thank you!
After some tests, I can change state and thermostat temperature using this kind of command in JS virtual device
controller.devices.get("Heating_13").performCommand("energySave", {"room":1}); controller.devices.get("Heating_13").performCommand("energySave", {"room":2}); controller.devices.get("Heating_13").performCommand("energySave", {"room":3}); controller.devices.get("Heating_13").performCommand("energySave", {"room":4}); controller.devices.get("Heating_13").performCommand("energySave", {"room":8}); controller.devices.get("Heating_13").performCommand("energySave", {"room":10}); controller.devices.get("Heating_13").performCommand("energySave", {"room":null})
I use "toggle button"
One line for each Heating control room and finally "null" option to change widget icon.
It exports well to Home assistant and works fine.
With home bridge it exports as a button without configuration, so it doesn't really work. You need to reinfect as a button via home assistant.
I will test some weeks and I will update.
Thank you Poltos for your help!
