Sorry, server has not completely started yet...
chemychemy
Same problem after reinstalling
Post by chemychemy »
PotoS,
I tried to reinstall the service, and same problem. I could give you access to the Rapsberry of my customer, just in case.
Regards.
chemychemy
It works fine with Safari, but we get the message "Sorry, serve
I got a customer with the same issue. It works fine with Safari, but we get the message "Sorry, server has not completely started yet..." with other browsers. It is a fresh intall May 2013.
I tried to remove the garbage from "data name="ZDDXML" invalidateTime="1362845803" updateTime="1362845843" ty.....", But it did not seems to work...and it is not a formal solution
But anyway, I got full access to the Raspberry, I would like to know what to do, or what you need to help us. Version? Logs I should look after?
Thanks in advance.
Can be fixed by /ZWaveAPI/Run
Can be fixed by /ZWaveAPI/Run/devices[NN].data.ZDDXML=""
This will delete the content of the obsolate ZDDXML element. This variable is not used anymore.
