Look inside the very old RaZ-OR module
https://github.com/pz1/Razberry/blob/ma ... nremote.js
starting at line 180
It does something with the Math.round function.
[userMODULE] OpenRemoteHelpers
pierre2302
Re: [userMODULE] OpenRemoteHelpers
It's perfect, thank you !!
Re: [userMODULE] OpenRemoteHelpers (iOS client)
There is a new completely rewritten beta release of the OpenRemote iOS client. Further instructions on the OR site.
Hi , I Check the operability of the commands (dimmer-->http://raspberry_ip:8083/OpenRemote/SwitchMultilevelSet/2/0/50) from the browser and this sends me the message "404 not found". This from openremote not work
See second warning on the Openremote pagewinston wrote:Hi , I Check the operability of the commands (dimmer-->http://raspberry_ip:8083/OpenRemote/SwitchMultilevelSet/2/0/50) from the browser and this sends me the message "404 not found". This from openremote not work
pierre2302
Hello
I think there is a problem on the alarmsensor command
we must replace:
by :
Necessary for the flood sensor and the smoke detector.
we must replace:
case "AlarmStatus":
// there are usually no instances for alarms
return (zway.devices[N].AlarmSensor.data.level.value == 0) ? "off" : "on" ;by :
case "AlarmStatus":
var T = params.shift();
return (zway.devices[N].instances[I].AlarmSensor.data[T].sensorState.value == 0) ? "off" : "on" ;
