websocket client
injecteer
Re: websocket client
Post by injecteer »
Then how can I call it and how can it work like charm?
this.ws = new sockets.websocket( wsUrl );
this.ws.send( s );
:o :shock:
Update:
`ws.push()` is undefined as of 2.2.2
injecteer
Post by injecteer »
I just discovered, that the
  new sockets.websocket( self.wsUrl );
sends no ping's. That leads to the connection termination by Nginx after a timeout.
Is there any way to send WS-pings out of the box?
Just add a setTimeout with a ping ;)
injecteer
Post by injecteer »
rgr, thats what I thought ;)
klaasjoerg
Post by klaasjoerg »
Hi. Did you finally found a solution?
I have the same issue and can't see it solved. My websocket-zwave-client is initiating a connection to a websocket server but closing down immediately again. My code devices looks like this right now (including a ping and settimeout) but no effect....
Any ideas?
var ws = new sockets.websocket("ws://192.168.1.61:23456/","toptron-protocol"); ws.onopen = function() { ws.send (" ping "); setTimeout(10000);  ws.send("set:LIGHT_OUT1=%%"); };
The websocket-server-debug-result is just:
client connected
disconnected
klaasjoerg
Meanwhile I found, that I get a step further, if I remove the whole "protocol" definition. (Of course this is not my solution, but at least I get a properly connect and ping etc.)
Ideas?
Not sure how this protocol thing work in WS. Do you need to specify it?
klaasjoerg
Unfortunately yes, because the websocket server is ignoring requests without protocol definition.
(In this case it's a Knaus camper that allows dimming lights etc. via websocket connection. Actually a cool thing putting zwave into a camper and do all the nice stuff).
Right now I am kind of stuck here, because without this, the project is in a dead end...
Can you send us in PM or by mail a sniplet of code to test it (if possible with access to that server) and a demo with correctly working handshake form a browser WS? We will then check our code
klaasjoerg
Direct access is probably difficult, because it's a camper. I'll try to copy the websocket server (raspberry based) and make some tests tomorrow. Will keep you informed.
