HomeKit gate all devices show “no response”
Topas
Re: HomeKit gate all devices show “no response”
Post by Topas »
Topas wrote:
27 Apr 2023 13:03
You have my ZAB Backup:
Please have a look at device #13 - there must be a specific problem with that device. It has problems for 1/2 year to integrate in the Homekit network. So I can be sure that this problem has nothing to do with the new Homekit version...
I thought I could fix the error by buying a new Z-Wave-me device ...
No answer - 7 days later...
6ft6 wrote:
05 May 2023 08:27
I am seeing the same issue after HomeKit upgrade. I then removed devices and Z-Wave.Me hub from HomeKit and now they can no longer be added. HomeKit no longer sees the hub/devices.
Please change the name of the HomKit Gate app (add any character to it) and save. Will it help?
Topas wrote:
08 May 2023 21:15
Topas wrote:
27 Apr 2023 13:03
Sorry for the delay, our engineers are looking it in with the specialized Apple ADK tool.
slytt
Post by slytt »
Hi Lostformers
Can you please share your JSON cvonfiguration for this homebridge plug in ?
using z-way 4.1.0 i'm getting the following logs with taking long time message forever
It seems i'm connected but no accessories are being fetched
Thank you
[10/05/2023, 10:04:23] [homebridge-zway] Launched child bridge with PID 16422
[10/05/2023, 10:04:24] Registering accessory 'homebridge-zway.ZWayServer'
[10/05/2023, 10:04:24] Registering platform 'homebridge-zway.ZWayServer'
[10/05/2023, 10:04:24] [homebridge-zway] Loaded homebridge-zway v0.5.0 child bridge successfully
[10/05/2023, 10:04:24] Loaded 0 cached accessories from cachedAccessories.0E4DF7A185F6.
[10/05/2023, 10:04:44] [homebridge-zway] This plugin is taking long time to load and preventing Homebridge from starting. See https://homebridge.io/w/JtMGR for more info.
slytt
Post by slytt »
Hello - can you or anyone kindly display their JSON file for this Homebirdge-zway plug in ?
I connect but cannot retrieve any accessories
Thanks a bunch
homebridge-zway-plugin] Launched child bridge with PID 8187
[16/05/2023, 12:49:43] Registering accessory 'homebridge-zway-plugin.ZWayServer'
[16/05/2023, 12:49:43] Registering platform 'homebridge-zway-plugin.ZWayServer'
[16/05/2023, 12:49:43] [homebridge-zway-plugin] Loaded homebridge-zway-plugin v1.0.1 child bridge successfully
[16/05/2023, 12:49:43] Loaded 0 cached accessories from cachedAccessories
hubert
Post by hubert »
No Response on all accessories since updating my Apple Home to new Home architecture today (and updating Apple TV & HomePod mini to iOS 16.5)
The Apple Home Architecture update has been out since March (see https://support.apple.com/en-au/HT213481)
Is HomeKit Gate App still being maintained, because it seems non-functional at the moment?
Apple HomeKit Gate App 2.4
Firmware version v4.1.0
UI version v1.15.1
Built date 03-05-2023 00:36:45
Accessories worked again briefly after power cycling HomePod, now No Response again
Homebridge v1.6.1 with a number of different plugins worked fine before and after the Home Architecture upgrade, only the Z-Way HomeKit Gate App seems to be having issues.
hubert
Post by hubert »
Migrated to Homebridge Zway Plugin (https://github.com/jmichas/homebridge-zway-plugin) in Homebridge and removed Z-Way Apple HomeKit Gate bridge
A lot of work to set the correct device types again, rename devices, move them to correct rooms, recreate scenes :/
Respectfully, I'm not going to buy Razberry or Z-Wave.me products again unless Apple Home integration is treated as a first class 100% supported feature. It seems to be considered optional and not a high priority at the moment
Topas
Post by Topas »
I got no refund on amazon neither I got a response on my problems. That is the worst customer service you could imagine...
lindm
Post by lindm »
It seems that Zway developers were not aware that a new HomeKit architecture was announced by Apple last year at WWDC 2022.
Then they failed to notice that the new HomeKit architecture was released with iOS 16.2 in December (and then withdrawn again).
Then in March, when the new architecture was released again, they were still clueless.
The moderator here who is apparently responsible for HomeKit (aivs) does not answer questions at all and only occasionally writes something like "HomeKit support works without problems".
The HomeKit plugin would not need an update for the new architecture if it was programmed correctly. My old Eve Bluetooth wall plug hasn't had a firmware update in years, and my Shellys with the alternative mongoose/HomeKit firmware were last updated in August 2022.
It seems to me that no one from Z-Wave.me uses HomeKit himself. It's just a tacked on feature to get money from Apple users.
At this point, we can only warn other HomeKit users not to buy Zway/Razberry.
6ft6
Post by 6ft6 »
PoltoS wrote:
09 May 2023 02:09
6ft6 wrote:
05 May 2023 08:27
Thank you, this worked and I am able to add devices again. Still no response tho.
