FGS-213
Re: FGS-213
Thank you for checking it. Yes, this looks like the best option. We will adopt it.
MrM.
Re: FGS-213
Post by MrM. »
Now this gives me a question about the FGS-223.
Can you tell me why the Watss are missing from the second device (see picture below)?
I have two meters 6.1 and 6.2. But only one device 6.1 Watts device.
In the Json file they are all defined:
"rename,0-50-0,Total consumption all",
"rename,0-50-2,Current consumption all",
"rename,1-50-0,Total consumption S1",
"rename,1-50-2,Current consumption S1",
"rename,2-50-0,Total consumption S2",
"rename,2-50-2,Current consumption S2",
But the second consumption is not shown.
Re: FGS-213
You can check on the start when VDevs are created. Search the log for postfix or devices.6.instances.2.commandClasses.50
MrM.
Re: FGS-213
Post by MrM. »
I restarted the server and searched the log file for "devices.6.instances.2.commandClasses".
Do you need more? Or is this the information needed:
2023-07-03 20:05:44.822] [I] [zway] Node 6:2 CC SwitchBinary Interview done
[2023-07-03 20:05:44.823] [I] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.data.interviewDone = True
[2023-07-03 20:05:44.823] [I] [zway] Interview for Node #6 finished.
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.37.data.interviewCounter = 9 (0x00000009)
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.37.data.level = False
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.supported = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.supported = True
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.version = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.version = 1 (0x00000001)
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.security = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.security = False
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.interviewDone = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.interviewCounter = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.interviewDone = False
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.interviewCounter = 10 (0x0000000a)
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.resettable = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.scalemask = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.security = True
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.interviewDone = True
[2023-07-03 20:05:44.823] [I] [zway] Node 6:2 CC Meter Interview done
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.interviewCounter = 9 (0x00000009)
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0 = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.sensorType = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.sensorType = 1 (0x00000001)
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.sensorTypeString = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.sensorTypeString = "Electric"
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.val = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.val = 0.050000
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.scale = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.scale = 0 (0x00000000)
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.scaleString = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.scaleString = "kWh"
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.ratetype = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.delta = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.previous = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.precision = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.precision = 2 (0x00000002)
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.intVal = Empty
[2023-07-03 20:05:44.823] [D] [zway] SETDATA devices.6.instances.2.commandClasses.50.data.0.intVal = 5 (0x00000005)
Re: FGS-213
Have you tried 4.1.0-27-g589c9812? There was an issue with the value on the last channel fixed in this version.
MrM.
Re: FGS-213
Post by MrM. »
Glad to test. Do you have a link for ubuntu?
I see only an arm package. https://storage.z-wave.me/z-way-server/ ... _armhf.deb
Re: FGS-213
Currently Pi build only.
