The latest version does not work on openelec due to missing lib.
./z-way-server: error while loading shared libraries: libarchive.so.12: cannot open shared object file: No such file or directory
[edit]:
There are more libs than that one missing, with these from Arch R-PI (http://us.mirror.archlinuxarm.org/armv6h/) I got it running:
libacl.so, libarchive.so, liblzma.so, liblzo2.so, libminilzo.so
If anyone else is running openelec and want a temporary solution until z-wave.me fixes this then download the below pkgs and add them to z-way-server/libs
NOTE: This worked for me, but I take no responsibility if it doesn't for you.
They are in usr/lib in these packages:
http//us.mirror.archlinuxarm.org/armv6h/core/libarchive-3.1.2-1-armv6h.pkg.tar.xz
http://us.mirror.archlinuxarm.org/armv6 ... pkg.tar.xz
BR gurra
New version of RaZberry is released
Question: will this release
Question: will this release work with a raspberry pi and a USB aeon z-stick? Or does it require the exact daughter board? (RaZpberry pi)
No, it won't. RaZberry s/w
No, it won't. RaZberry s/w relies on our extension of Z-Wave Serial API protocol that is implemented in RaZberry daughter board.
New release... Problem !
1) Latest up date doesn't work for me. I lost my Fibaro module.
2) Also interested in scenes/automation management tap (local) !
3) I am investigating learning code to manage my Z-Wave network through the Razberry board. Which way to go Python or Javascript... It is not clear for me ?
Problem with Fibaro door/temp sensor
In previous version, I linked this device.
In this version, I had problems, and remove and unlink.
Now I can't link anymore the device.
Please give us more feedback
Please give us more feedback and logs.
1) please tell us more. What
1) please tell us more. What means lost? If it was included in RaZberry, it can no disappear.
2) Will come - we are working on this part.
3) RaZberry have a JavaScript engine inside. You can use JavaScript to make home automation rules.
Problem with latest release
Z-Way version v1.3
I cannot include Fibaro Double Relay Switch FGS-221 v2.1 - v2.3
I push "re-activate" button and then push 3 times Fibaro Switch "B" button --> nothing happened !
I reset Chip Controller --> no improvement
Where do I find the log ?
Sorry I think I reply in a wrong place...
1)
a- "Lost" means cannot switch "on" & "off" from Z-way, as I use to do ! (I am in test mode !)
b- So I've excluded the fibaro switch (FGS - 221 - V2.1 - v2.3)
c- And I cannot re-include the switch, so I am stuck !
2) thanks
3) ok, so I'll start learning
1)
2) thanks
Here is my log !
Here is my log !
[2013-05-26 18:49:32.159] Adding job: Add/re-include node to network
[2013-05-26 18:49:32.167] SENDING (cb 0x42): ( 01 05 00 4A 41 42 B3 )
[2013-05-26 18:49:32.178] RECEIVED ACK
[2013-05-26 18:49:32.188] RECEIVED: ( 01 07 00 4A 42 01 00 00 F1 )
[2013-05-26 18:49:32.189] SENT ACK
[2013-05-26 18:49:32.189] SETDATA controller.data.lastIncludedDevice = Empty
[2013-05-26 18:49:32.190] SETDATA controller.data.lastExcludedDevice = Empty
[2013-05-26 18:49:32.190] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2013-05-26 18:49:32.190] SETDATA controller.data.controllerState = 1 (0x00000001)
[2013-05-26 18:49:51.069] Job 0x4a (Add/re-include node to network): Job not removed before timeout (awaiting for more callbacks?)
[2013-05-26 18:49:51.069] Job 0x4a (Add/re-include node to network): Cancelling
[2013-05-26 18:49:51.069] Job 0x4a (Add/re-include node to network): fail
[2013-05-26 18:49:51.069] Adding job: Add/re-include node to network
[2013-05-26 18:49:51.081] SENDING (cb 0xc5): ( 01 04 00 4A C5 74 )
[2013-05-26 18:49:51.092] RECEIVED ACK
[2013-05-26 18:49:51.092] Removing job: Add/re-include node to network
[2013-05-26 18:49:51.136] RECEIVED: ( 01 07 00 4A 42 06 00 00 F6 )
[2013-05-26 18:49:51.137] SENT ACK
[2013-05-26 18:49:51.137] Job 0x4a (Add/re-include node to network): Done
[2013-05-26 18:49:51.138] SETDATA controller.data.controllerState = 0 (0x00000000)
[2013-05-26 18:49:51.138] Removing job: Add/re-include node to network
[2013-05-26 18:50:09.990] Job 0x4a: deleted from queue
[2013-05-26 18:50:10.025] Job 0x4a: deleted from queue
