I can provide the first "draft" version of Wire and BMP180 libraries.
You can get it from my dropbox: https://www.dropbox.com/s/5gq0hzz1dd67v ... 0.zip?dl=0
Here you will find:
- updated Wire.cpp/Wire.h
- updated BMP180 library (in folder ZUNO_BMP180)
- python script (bmp_math_test.py) to test math of BMP180 (it reads RAW data from Z-Uno and make all math operations on your PC). Works with BMP180Dumper sketch (look in ZUNO_BMP180/examples)
To update library you have to replace Wire.cpp/Wire.h in
<your zuno package folder>/hardware/zw8051/2.0.6/cores
To update BMP180library replace ZUNO_BMP180 folder in
<your zuno package folder>/hardware/zw8051/2.0.6/libraries
I have the first results:
- Fixed issues with ack/nack and "false" stop sequence in wire library.
- Fixed some numerical issues in math operations in BM180 library. Now it gives the same results with with the same algorithm written in python (see bmp_math_test.py).
- At this moment we use original fixed-point algorithm from Bosch datasheet.
- Arduino library uses alternative floating point realisation from here http://wmrx00.sourceforge.net/Arduino/BMP085-Calcs.pdf. We can use this instead of fixed-point code, but it will produce a lot of code compared with fix-point variant. Float point operations is a pain for 8051 architecture. I try to compare the values calculated these methods but I didn't finished my script yet.
