Looks like.
Well, there was actually problem with scenes and schedules, so I thought I am not full on 3.0.0. version. All elements in my scene were red and with error text saying that elements does not exists. And no functionality/option to repair rule. On the other hand scene works fine (even today).
And there was also text on Z-Way UI upgrade page saying my firmware version is 2.3.8. ??.
We will solve this bug later. Now I am stucked and can not acces Z-Way UI.
Yesterday I repeated procedure of installing 3.0.0.:
sudo apt-get update
sudo apt-get install dirmngr -y
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7E148E3C
sudo bash -c 'echo "deb https://repo.z-wave.me/z-way/raspbian stretch main contrib" > /etc/apt/sources.list.d/z-wave-me.list'
sudo apt-get update
sudo apt-get install z-way-full
No difference, problem stil exists. And most things were not updated because they are 'already installed'.
Please help me I really do not know what to do.
Alex
Z-Way v3.0.0 Release
Re: Z-Way v3.0.0 Release
Same problem here:
After upgrade interface shows: "The current firmware version is: v2.3.8". Also th build.js says it is on v2.3.8 instead of v3.0.0.
dpkg -l z-way-server on Raspbian (Stretch) shows " z-way-server 3.0.0 armhf RaZberry/Z-Way smart home gateway"
I wanted to thank the developers!
Version 3 works great for me !
All the problems I had with the software have been fixed.
Raspi 3, Zwave.me 4.1.0.
Poltos,
really need your cooperation/advice to solve my 'downgrade' problem. There is no way to connect Z-Way.
As you suggested I tryed to upgrade, but nothing changes.
Here is my upgrade procedure Log file:
pi@raspberrypi:~ $ sudo apt-get update
Dobi:1 http://archive.raspberrypi.org/debian stretch InRelease [25,4 kB]
Dobi:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
Dobi:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11,7 MB]
Zadetek:4 https://repo.z-wave.me/z-way/raspbian stretch InRelease
Zadetek:5 https:/repo.z-wave.me/z-way/raspbian stretch InRelease
Dobi:6 http://archive.raspberrypi.org/debian stretch/main armhf Packages [221 kB]
Pridobljenih 11,9 MB v 12s (961 kB/s)
Branje seznama paketov ... Narejeno
pi@raspberrypi:~ $ sudo apt-get install dirmngr -y
Gradnja drevesa odvisnosti
Branje podatkov o stanju ... Narejeno
dirmngr is already the newest version (2.1.18-8~deb9u4).
0 nadgrajenih, 0 na novo nameščenih, 0 bo odstranjenih in 215 ne nadgrajenih.
pi@raspberrypi:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7E148E3C
Executing: /tmp/apt-key-gpghome.qm8lwvx1fk/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 7E148E3C
gpg: key 2222290F7E148E3C: "Z-Wave.Me <info@z-wave.me>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
pi@raspberrypi:~ $ sudo bash -c 'echo "deb https://repo.z-wave.me/z-way/raspbian stretch main contrib" > /etc/apt/sources.list.d/z-wave-me.list'
Zadetek:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Zadetek:2 http://archive.raspberrypi.org/debian stretch InRelease
Zadetek:3 https://repo.z-wave.me/z-way/raspbian stretch InRelease
Zadetek:4 https:/repo.z-wave.me/z-way/raspbian stretch InRelease
W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (main/i18n/Translation-sl_SI) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (main/i18n/Translation-sl) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (main/i18n/Translation-sl_SI.UTF-8) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Packages (contrib/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Packages (contrib/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (contrib/i18n/Translation-sl_SI) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (contrib/i18n/Translation-sl) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (contrib/i18n/Translation-sl_SI.UTF-8) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
W: Target Translations (contrib/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/z-wave-me.list:1 and /etc/apt/sources.list.d/z-wave.me.list:1
pi@raspberrypi:~ $ sudo apt-get install z-way-full
z-way-full is already the newest version (1.0-latest-version).
gpg: unchanged: 1
What is the exact problem?
Have you cleared cookies after upgrading?
My problem? I am trying to explain my problem in every single post I published above. Which part you do not understand?
Current situation: CAN NO ACCESS Z-Way UI. Not locally, not remote. Only using POPP android App or Alexa I can control existing devices.
1. Weeks ago I followed your instructions how to upgrade to 3.0.0.
2. After upgrade (and cookies cleared!) all worked fine except scenes and schedules were totally messed up - full of red errors and no usual programming menu.
3. I opened upgrade page of Z-way UI which said: "The current firmware version is: v2.3.8". That was wrong (!) message since I was already on 3.0.0.
4. Unfortunately I performed offered 'upgrade'. From then on I CAN NOT log into Z-way user interface. When I type usr and pwd (find.z-wave.me) in IE or Chrome, Z-Way does not log in. Locally or remote. No error message. Web browser just hangs up/freezes in Internet Explorer or it falls in some kind of infinite loop trying and trying to load page... in Chrome browser.
I am using same usr and pwd as is used on my mobile POPP.
5. As you suggested i repeated upgrade procedure. No succes in logging in.
6. Now I am in a 'locked out' situation and am more than two weeks asking for someone's help.
Alex
Alex
I have the exact same problem and no solution! And I'm sick doing the process all over again!
Right now I'm looking for a way to downgrade to 2.3.8 witch works like a sharm for me. But I haven't found a way to do that...
Any suggestions?
Kay
Any suggestions?
Kay
I decided to Install a new clean system with Z-way v3.0.0 , but in the fresh installed but empty smart home central it is not allowed to install apps.
Are there any problem in v3.0.0 with the apps instalation?
Haven't had any problems with apps. Did you clean browser's cache and cookies?
What is the command for cleaning browser´s cache and cookies
