Razberry Pro Firmware / SDK
Gaby
Re: Razberry Pro Firmware / SDK
Post by Gaby »
Upps, UUID info appears empty
You can try to manually download the file and use the button to upgrade the firmware. https://service.z-wave.me/expertui/uzb/ ... .00.00.gbl
Gaby
Post by Gaby »
Thanks for the suggestion, I did it, I tried to upgrade the firmware with the file 'Razberry07.20.00.00.gbl'
(Expert UI) Network -> Firmware update -> Upload firmware -> select file -> ok
but I got an error saying: 'Z-Wave expert UI - Error Unable to update data. /ZWave.zway/ZMEFirmwareUpgrade'
Please help, this controller is unstable.
The current firmware version is: 7.36 [Bootloader: 65535]
Thanks in advance
P.S.:
/: None (25-02-2024)
nodeId: 1 (25-02-2024)
homeId: -281911153 (25-02-2024)
SUCNodeId: 1 (25-02-2024)
isPrimary: true (25-02-2024)
isInOthersNetwork: false (25-02-2024)
isRealPrimary: true (25-02-2024)
isSUC: true (25-02-2024)
SISPresent: true (25-02-2024)
libType: Static Controller (25-02-2024)
SDK: (25-02-2024)
ZWlibMajor: 7 (25-02-2024)
ZWlibMinor: 19 (25-02-2024)
ZWLib: 1 (25-02-2024)
ZWVersion: 10 (25-02-2024)
ZWaveChip: ZW0700 (25-02-2024)
APIVersion: 07.36 (25-02-2024)
APIVersionMajor: 7 (25-02-2024)
APIVersionMinor: 36 (25-02-2024)
manufacturerId: 327 (25-02-2024)
vendor: RaZberry by Z-Wave.Me (25-02-2024)
manufacturerProductType: 1025 (25-02-2024)
manufacturerProductId: 257 (25-02-2024)
capabilities: 2,3,4,5,6,7,8,9,10,11,16,18,19,20,21,22,28,32,33,34,35,36,39,40,41,42,43,44,45,46,55,56,57,58,59,60,63,65,66,68,69,70,71,72,73,74,75,77,79,80,81,83,84,85,86,87,88,94,95,96,97,98,99,101,128,144,146,147,152,160,162,164,165,166,168,169,171,189,190,191,208,209,210,211,212,214,215,216,217,218,219,220,221,222,223,231,232,242,244,245,248 (25-02-2024)
controllerState: 0 (25-02-2024)
nonManagmentJobs: 0 (25-02-2024)
lastIncludedDevice: 0 (25-02-2024)
lastExcludedDevice: 0 (25-02-2024)
secureInclusion: 2 (25-02-2024)
oldSerialAPIAckTimeout10ms: 150 (25-02-2024)
oldSerialAPIByteTimeout10ms: 15 (25-02-2024)
curSerialAPIAckTimeout10ms: 10 (25-02-2024)
curSerialAPIByteTimeout10ms: 10 (25-02-2024)
countJobs: false (25-02-2024)
memoryGetAddress: 32768 (25-02-2024)
memoryGetData: 14,177,183,2,214,208,193,158,177,20,136,138,133,102,129,188,187,182,224,70,222,51,118,231,9,85,17,184,36,88,137,45,184,234,41,224,84,189,92,92,209,28,44,109,235,71,130,31,122,96,165,30,144,224,147,99,185,135,91,3,90,85,72,84 (25-02-2024)
memoryManufacturerId: None (25-02-2024)
memoryType: None (25-02-2024)
memoryCapacity: None (25-02-2024)
functionClasses: 2,3,4,5,6,7,8,11,18,19,20,21,22,23,32,33,34,35,36,39,41,42,43,44,45,57,58,59,63,65,66,68,70,71,72,73,74,75,76,77,79,80,81,82,83,84,85,86,87,88,94,96,97,98,99,128,146,147,186,190,208,209,210,211,242,243,244,245,248 (25-02-2024)
functionClassesNames: SerialAPIGetInitData,SerialAPIApplicationNodeInformation,ApplicationCommandHandler,GetControllerCapabilities,SerialAPISetTimeouts,GetSerialAPICapabilities,SerialAPISoftReset,SerialAPISetup,SendNodeInformation,SendData,SendDataMulti,GetVersion,SendDataAbort,RFPowerLevelSet,GetHomeId,MemoryGetByte,MemoryPutByte,MemoryGetBuffer,MemoryPutBuffer,FlashAutoProgSet,NVMGetId,NVMExtReadLongBuffer,NVMExtWriteLongBuffer,NVMExtReadLongByte,NVMExtWriteLongByte,ClearNetworkStats,GetNetworkStats,GetBackgroundRSSI,RemoveNodeIdFromNetwork,GetNodeProtocolInformation,SetDefault,ReplicationReceiveComplete,AssignReturnRoute,DeleteReturnRoute,RequestNodeNeighbourUpdate,ApplicationNodeUpdate,AddNodeToNetwork,RemoveNodeFromNetwork,CreateNewPrimary,ControllerChange,AssignPriorityReturnRoute,SetLearnMode,AssignSUCReturnRoute,EnableSUC,RequestNetworkUpdate,SetSUCNodeId,DeleteSUCReturnRoute,GetSUCNodeId,SendSUCNodeId,AssignPrioritySUC ReturnRoute,ExploreRequestInclusion,RequestNodeInformation,RemoveFailedNode,IsFailedNode,ReplaceFailedNode,GetRoutingTableLine,GetPriorityRoute,SetPriorityRoute,RFPowerLevelGet,SendTestFrame,SetPromiscuousMode,PromiscuousCommandHandler,WatchDogStart,WatchDogStop,ZMEFreqChange,ZMERestore,ZMEBootloaderFlash,ZMECapabilities,ZMESerialAPIOptions (25-02-2024)
softwareRevisionVersion: v3.2.3 (25-02-2024)
softwareRevisionId: 54744b038d758e35eece3b60540edf4b0d7b3910 (25-02-2024)
softwareRevisionDate: 2022-04-06 04:56:23 +0300 (25-02-2024)
uuid: None (25-02-2024)
hardware: None (25-02-2024)
programmerId: None (25-02-2024)
productionSeq: None (25-02-2024)
uartSpeed: None (25-02-2024)
bootloader: None (25-02-2024)
version: None (25-02-2024)
crc: 65535 (25-02-2024)
firmware: None (25-02-2024)
build: None (25-02-2024)
caps: None (25-02-2024)
maxNodes: None (25-02-2024)
staticApi: None (25-02-2024)
maxPower: None (25-02-2024)
backup: None (25-02-2024)
wup: None (25-02-2024)
advancedIMA: None (25-02-2024)
longRange: None (25-02-2024)
ultraUART: None (25-02-2024)
swapSubvendor: None (25-02-2024)
promisc: None (25-02-2024)
zniffer: None (25-02-2024)
jammingDetection: None (25-02-2024)
frequency: EU (25-02-2024)
deviceRelaxDelay: 3 (25-02-2024)
pauseSending: 0 (25-02-2024)
promiscMode: false (25-02-2024)
statistics: None (25-02-2024)
backgroundRSSI: None (25-02-2024)
channel1: 153 (19:11)
channel2: 152 (19:11)
channel3: 152 (19:11)
RFTxFrames: 182 (19:04)
RFTxLBTBackOffs: 0 (19:04)
RFRxFrames: 736 (19:04)
RFRxLRCErrors: 0 (19:04)
RFRxCRC16Errors: 0 (19:04)
RFRxForeignHomeID: 18 (19:04)
priorityRoute: None (25-02-2024)
dstNodeId: None (25-02-2024)
routeType: None (25-02-2024)
speed: None (25-02-2024)
hops: None (25-02-2024)
ch1Threshold: 127 (25-02-2024)
ch2Threshold: 127 (25-02-2024)
ch3Threshold: 127 (25-02-2024)
detected: 0 (25-02-2024)
homeName: (14-12-2021)
homeNotes: (14-12-2021)
S2RequireCSA: false (25-02-2024)
smartStart: None (14-12-2021)
requestFrom: None (25-02-2024)
dskProvisioningList: None (14-12-2021)
includingDSK: None (25-02-2024)
S2AutoInclude: None (25-02-2024)
pin: None (25-02-2024)
keys: None (25-02-2024)
Gaby
Post by Gaby »
I managed to install the new firmware but I had to upgrade my Raspberry with the latest Z-way firmware before, with this running I could see the latest firmware and I could upgrade it,.. thanks
